I tried this rom on my I68G (HDMI sound), Dolby Digital and DTS work,
the DTS HD Master has always cut, the Dolby Digital plus does not work
And there's a shift in Dolby Digital true HD.
And my remote can not turn on, (with HPH NT-V8 RK3368 Marshmallow ROM the remote work).
Did you try Ugoos UT4 firmware they released?
Also try latest SPMC Krypton.
mo123 - I loaded your latest rom on my Ugoos UT4 , works perfectly on my TV in the lounge, super fast and NO audio stutter (connected via Yamaha receiver), but when I plug it directly into my 46" Samsung Smart LED TV in the bedroom on hdmi port 3 it shows "No Signal" (or the signal comes and goes but does not display a picture), I then plug my spare MyGica TV Box in using the same HDMI cable into the same HDMI port 3 on the TV in the bedroom and it works perfectly fine, any suggestions would be helpful as I am a loss and would really like to use this rom?
Check if your TV has a Deep or High Color Setting and disable it.
I know some tv's can't work with all HDMI ports as some are normal ones and others can display more colors, use high color(or some other name) that might not work with all equipment.
Other equipment in HDMI 1,2 ports, can you swap them around perhaps with HDMI 3?
Some HDMI cables might also not work with different HDMI port versions, so maybe try a different cable.
Also a similar case, I used a RK3288 with it's own cable connected to my tv, then I use the same cable to connect an Amlogic S905 and then I also get no picture, but by using it's own cable then it displays a picture and that cable then also doesn't work again with the RK3288.
mo123 , gefattern - Hi there, I know my TV supports Wide Color Enhancer Plus (Samsung UA46F7500BT) but don't see an option to disable this, my UT4 use to work on this TV before, I have switched to different HDMI ports, as well as change resolution down to 720p and tried different working HDMI cables including Ugoos cable, even performed a TV reset last night, nothing helped but when I plug the UT4 into my LG TV it works, I even bypassed my Yamaha Receiver and plugged the HDMI cable directly into the LG TV, that worked too. The issue is only with the Samsung TV, but yet when I plug MYGica ATV-582 into Samsung in the same ports that works, I'm at a loss, this is a weird problem.
