UT4 RK3368 Marshmallow ROM by mo123
    Hi leoben ,
    If you look at the first post of this Thread you find all Info over the released Roms .
    It is of course MM .
    nice Day
    gefattern
    Hi gefattern,
    I apologize for my weak English language knowledge.
    That's what I was looking at, in the name of the topics, the "Marshmallow ROM".
    I've been looking for a solution to a problem so far unsuccessfully.
    Zidoo does not want to create android 6 firmware and does not improve existing errors.
    Does this ROM work with HBO GO Hungary app?
      Originally posted by Leoben View Post
      Hi gefattern,
      http://goo.gl/tekFx5
      I think the provider of the app restricts it to only work on phones & tablets without HDMI output.
      Then there is nothing you can do.
      UT4 2.0.0 firmware has a HDMI deception setting you can try but it doesn't work for all apps.
        Hi There, how do I switch my TV Box back on once I have put it to sleep, pressing the On button on the unit does nothing?
          Hi erpenstine ,
          did you tried the stock Remote too ??? Mo made for this Rom a new ShutdownMenu ,
          i am not sure but i think it did not work on my Box too , but i dont need it . I use the stock
          RebootMenu or Reboot App .
          Does Daydream work ???
          good luck
          gefattern
            Hi erpenstine ,
            good luck
            gefattern
            @gefattern
            Hi there
            The stock remote switches the unit on and off except when the TV box has been off overnight, then I have to unplug the power to get the TV Box back on.
            When I use the shutdown menu I can only power it up by unplugging it.
            I use to use the stock ROM MM 2.0 as well but I find the audio stutters badly in YouTube, even with the stock 5.1 ROM, Mo123 MM ROM is the only ROM that it does not stutter at all.
            Do you not have the YouTube audio stutter issue with Ugoos stock ROM?
            Have a great day
            erpenstine.
              Hi erpenstine ,
              i had much more then this , with every 5.1 Rom i got Wifi on/off issues and Stutters in
              Audio & Video , thatˋs why i still use KK on my UT3 . Hope Ugoos will realease the A7
              in near Future .
              good luck
              gefattern
                RK3368 and Android 5.1 pairing can be the problem?
                Can you find out if ROM works with HBO GO Hungary app?
                You do not need to register for free content.
                Do you see the following error message or do you see the picture?
                ...Please turn off the screen to the other, because that is not allowed, only then you can continue playing!...
                  I will test it, hope it is not geo restricted and app can work outside Hungary.
                  Will let you know.
                    hello mo123, I have been used your rom on tronsmart R68 in two weeks, There is an issue too, connecting internet with wifi is very slow(box near to modem). I tested with speedtest by okla, it was 1 mbps. Test result was 20 mbps with tronsmart stock rom. I don't want to use stock rom because there is so much audio and video stuttering. Can you fix it pls in your new rom.
                    I used your other rom HPH NT-V8 on my device, it has audio stuttering for 50 second, and has slow wifi connection too.
                      Hi Mo ,
                      first i had problems backing up my Files of the latest Rom , TitaniumB. & EasyAppB. only where able to backup to
                      stock Storage , so i had to copy all to SDCard on my own , even copy this big Files made problems .
                      Before i start flashing your new HPH Rom and test it , i installed "MagiskManager.apk" without problems on my
                      UT4 , it says it is rooted , but "Magisk" self "latest 13.1" ask for install in "BootImagePath""mmcblk0p4"(auto) , this
                      is the default choice it shows . Below stands "download & install" gone try and report later . Press thumbs .
                      greetings
                      gefattern
                        Hi Mo once more ,
                        to flash the Magisk.zip we need a TWRP Recovery . Is there a working TWRP for RK3368 MM Rom ???
                        have a nice Day
                        gefattern
                          Latest magisk is 13.2
                          Latest magisk Manager is 5.0.5 i think...
                            Hi jit18 ,
                            maybe yes but we can not use it without a Recovery or ???
                            greetings
                            gefattern
                              The instructions are a bit unclear...
                              There are two ways to install magisk:
                              1.boot to recovery and flash ther magisk.zip through twrp
                              2.install the magisk Manager then install the magisk.zip through the app...
                              The only certain thing is that if something goes wrong you need twrp to Uninstall magisk
                              New Magisk version 13.3
                              New Magisk manager version 5.1.0
                                Hi jit18 ,
                                i tried it with MagiskManager , but it only downloaded the .zip , to install
                                with a working TWRP . I dont have TWRP installed and dont know if a
                                working TWRP for RK3368 exist .
                                have a nice Day
                                gefattern
