Ugoos UT6 full 1080p firmware install on Scishion V88 with working wifi
Originally posted by DanMan View Post
I just installed the v1.2 and used the WiFi patch provided here. Worked straight away, though it has messed with a few other things as I said. Maybe you have yet another WiFi chip?
Then I installed patchssv6051p2.zip and reboot, but I could not connect Wi-Fi. Then I downgraded to Ugoos Firmware version 1.1.1, installed TWRP 3.0.1 and then patchssv6051p2.zip, cleaned the date and cache , As soon as I started and put the Wi-Fi worked, but for a long time, I think I rebooted the box and could not turn Wi-Fi on.
I do not know what went wrong, but apart from leaving the device very strange, the Wi-Fi did not call anymore. I ended up giving up and installed version 5.1.1 for the A95X R1 device. But this is not a very cool firmware, to know a better one please let me know.
I have the Scishion V88 Plus and whenever i try and flash this firmware, it fails on the check firmware part.
Can someone tell me if I am doing something wrong?
Attached is a screenshot of what happens when I try to flash the firmware except it fails on check firmware not download.Last edited by SybRiN; 13 July 2017, 06:39.
Originally posted by Novato View Post
So ... I ended up going to the forum 4PDA in search of more information and downloaded the rknand version from there, I thought it would be the same thing, I wanted to install what I downloaded there to make sure I would not have a brick box. I did, with version 1.2.0 of Ugoos Firmware, I installed TWRP 3.0.1 via Terminal Emulator using the rknand_recovery option.
I have same problem as rcp,
I tried also with AndroidTool 2.35 as suggested.. but alwais receive error "loading firmware failed".. may be problem is TWRP.img file?? (I downloaded it 2 times for be sure but nothing..)
It's correct that in AndroidTool 2.35 I go on "upgrade firmware --> firmware" and then select the TWRM.img file?
What is the colour of your A/V & SPDIF ports ?
V88 with A/V & SPDIF ports orange = firmware with bootloader 2.31 is working on it (firmware with bootloader 2.32 working fine too)
V88 with A/V & SPDIF ports black = firmware with bootloader 2.32 is working on it (firmware with bootloader 2.31 not working)
Ugoos UT6 full 1080p firmware is with bootloader 2.31
No solution to install Ugoos UT6 full 1080p firmware on V88 with A/V & SPDIF ports black.
Always an error when you try to install the firmware with all rockchip tools : RK Android Tool (all version), RK Batch Tool (all version), rkflashtool (linux) or rkflashkit (linux)
Originally posted by manu_manu4 View Post
Hello,
If you read well my post and post of "rcp" you understand that problem is only with file "TWRP recovery.img"
I installed without problems Ugoos UT6 Firmware and work well (yes, I have V88 with A/V & SPDIF ports orange) only problem is that I does not know how to flash TWRP... sure it's a problem software on PC because TWRP.img need to be loaded by AndroidTool also if TV Box is still not connected.. it's software trouble on PC, something that's not right and I miss what..
I ask help to persons that Installed "TWRP recovery.img" on V88.......... what software on PC you used? Version exact? Did you used "TWRP recovery.img" dowloaded in first page? Can you give basic instructions?
THANKS
I have tested TWRP but after 10 secondes my TV screen became green.
Best way is to download the zip.
Extract it.
Copy with x-plore or es-explorer files in the system directory to your /system
give right to folders and files (open META-INF\com\google\android\updater-script to see the rights to give)
and flash kernelV88_6.img (kernel partition) & bootssv6051p.img (partition) with rk android tool
Hi, please, I have a TV BOX MSQ-4K with the following card R329Q_V2.0 wifi SV6051P RK3229, but all the notes I downloaded nothing worked. I hope this file that has published UGOOS UT6, work, but the MEGA link is broken, can you send me an email or post somewhere? My email [email protected] Thanks
There are currently 2930 users online. 0 members and 2930 guests.
