Scishion V88 (RK3229 1G/8G) Android TV Rom
    Manu man, anything for V88 Plus?
      delete pls
        I have no V88 Plus to test
          V88 Plus rom android 6
          Add DRM to Android 6 with RK3229 processor (working with v88)
          http://freaktab.com/forum/tv-player-...-android-6-0-1
          Transform to Android TV
          http://freaktab.com/forum/developmen...ox-pro-h96-pro
            No wifi for me! I own the non plus model!
              What version ?
              Ram ?
              Rom ?
                Flashed over stock rom Android 6.0.1, model is V88 1GB RAM/ 8GB ROM
                  Originally posted by manu_manu4 View Post
                  Sorry,
                  i have no V88 plus, i's why i put (RK3229 1G/8G) in the title.
                  Chipset no be the same.
                  i just modded 6.0.1 rom from gearbest.
                  Do you have original rom to modded it ?
                  Which device do you currently own, and what is the best firmware in your opinion for V88 or RK3229 Box? I'm trying Ugoos UT6 and although it's great it has a lot of loose things.
                    hi im looking for the v88 plus rom android 6 and the link is down im also in a bad situation with no wifi and no original rom for the v88 plus at the moment im running v88 plus mini firmware as it was the only one i could find..... any one know where the v88 plus roms are?
                    Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
                    HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
                    ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
                      If that's all you're looking for, here it is:
                        Hey
                        I just installed your rom and I'm really impressed. Good work.
                        I have 3 questions.
                        When I start a Video with Amazon VOD the app crashes.
                        Second. Is there a way to configure the Remote and sign buttons to actions Like: Pause/Play, forward, backward in Netflix.
                        And I wanted to tryout muppen64 with my N64-Adapter. Saddly it won't find the C-Buttons and the Analog-Sick wont work in Games.
                        Regards iak
                          thanks. will try this on my 1/8GB V88.
                            flashed this with my V88 but wifi not working. any idea?
                              wifi not working. V88 4K user here.
                                Hi manu_manu4 , all right? I saw that you did an ATV ROM a while ago, I do not know if you still have the device, but have a base ROM recommendation to work, the A95X R1 Android 6.0, I believe you will not have problems with the buttons and etc. Even if you are no longer with the Box, please tell me how to do the ROM ATV, such as which tool to extract the ROM and repack into IMG. What is the correct way to put TVStock Gapps in ROM, simple things I know, but for every ROM there is a better way to work.
