Best regards
Scishion V88 (RK3229 1G/8G) Android TV Rom
Originally posted by karelkopp View Postany rom with android TV not working on VB/VR devicesits will be great if will someone make this for us
Probably V88 on the outside, plus the motherboard belongs to another model, something similar to what happens with my old MXQ Pro, it comes with that name on the outside, but inside it owns the motherboard of a V88/MX4 ... My suggestion is that you find the device to which the motherboard of your devices belong, after which you will have many other firmwares to test.
we found firmware whats working and i think we have only new revision for V88 but we want modified image with android TV like in this manual http://freaktab.com/forum/developmen...ox-pro-h96-pro problem is this manual not works for me
Originally posted by D3v1L View PostHello to all sorry for my english but I'm using a translator I have a problem with box out there is written M8S but on the motherboard there is written M4XN V02 I would like to restore the firmware what do I need?
Originally posted by D3v1L View Post8G 1G ZXD
2017-02-09
WW161220089
DRM for netflix e timvision??
It seems the Italian apps blocks streaming on tv boxes and only want to work on phones & tablets even if you have DRM and an unrooted device.
Originally posted by Novato View PostProbably V88 on the outside, plus the motherboard belongs to another model, something similar to what happens with my old MXQ Pro, it comes with that name on the outside, but inside it owns the motherboard of a V88/MX4 ... My suggestion is that you find the device to which the motherboard of your devices belong, after which you will have many other firmwares to test.
Under:
Chiptrip
TEAN E120339
94v-0ML1
Over:
(On the board itself)
XT-MX4VB-V02
2017-06-28
(On top of the sd card slot)
MX4VB
8G/1G ZXD
2017-08-25
WW17080045
Thanks a lot
Best regards
Did also someone elses V88 Mini box suddenly stop working proper?? Since a few days (without any changes) my box reboots after messages like "Google play service stopped" and other apps are stop working. I tried to clear cache through recovery mode, deleted some apps (now I have around 1,5GB free space) and cleared also the cache of Google play service. The device worked then yesterday evening for around 12h and then stopped again working with the error messages and stays at the boot-up "Android-logo". When you unplug and replug the device it starts to Android again, but stopps working after a few minutes again with the same issue.
Any ideas or suggestions?
There are currently 3471 users online. 1 members and 3470 guests.
