Lava Xtron without HDMI
Originally posted by kyusuf85 View Postnothing happened when i press volume up and power key its goes clockwork mode can i update it from zip rom
You found out how to boot to recovery mode, so now there is a different combination to get into flash mode.
Since you are changing parameters, really it wouldn't help to flash this ROM via CWM...the parameters have to stay the same that way.Randy
Originally posted by rrileypm View PostYou found out how to boot to recovery mode, so now there is a different combination to get into flash mode.
To get the Tab working it would be better if he flashes the original update.img using rkbatch tool. If he has the drivers installed correctly rkbatch will recognise the Tab, just by pressing the power+vol(up) keys. Once he has the factory ROM installed he can use your ROM. I would suggest to flash the CWM alone first and take a backup of the factory ROM before flashing the entire ROM as if something goes wrong, its easier to use the CWM to go back rather than flashing the whole ROM again.
Unfortunately, my Tab has gone for repair as the USB groove was very loose and the battery was not holding charge. I will get my battery changed by this week end hopefully..
Thanks for the help.Randy
Originally posted by kyusuf85 View Posti tried every method but my lava xtron(without hdmi) is automatically going cwm mode. can i get cynogenmod for my tab
And meanwhile Randy could help in making a CWM mode flashable zip as he made for M6. So that you could flash it from CWM itself!
Re: Lava Xtron without HDMI
I didn't actually make the CWM version...I just added a template to make your own.
It is in the M6 kit if you want to download it...it will work with any of my ROMs.
Keep in mind that the parameters are different than stock...so I wouldn't recommend flashing directly from stock to my ROM. You have to flash at least once by PC to set parameters and to install CWM, anyway.Randy
lava tab
Originally posted by rrileypm View PostI didn't actually make the CWM version...I just added a template to make your own.
4.2.2 Rom for xtron(w/o Hdmi)
hi riley,
I have also tried xtron+ rom on my xtron and its workin except for sound,wifi, battery and orientation sensor got reversed. I initially understood it was not possible to make 4.2.2. rom for xtron but you told pradipsoman, you will provide one. So, If u have made 4.2.2 ROM for xtron please provide me the download link.
Really appreciate your work.
regards,
ultiracer
Hi Randy
I have OEM tablet(Scopad SP0718), it's same to body with Xtron (not Xtron+) and I think it same HW too.
I test stock rom from Xtron it work fine on my tab.
I share my custom rom in Thailand at https://www.facebook.com/groups/TabletScopeClub
Can I share my custom rom on here? : o
I think it help to many people so happy.
sorry for bad English.
\\\ Anucha ///Last edited by Anucha; 09 October 2013, 22:11.
Yes...you can feel free to share your custom ROM for this tablet here on Freaktab.
I'm glad to see a developer who has one of these tablets who can provide additional support....who can actually test.
Thanks for your post!!!!!
RandyRandy
Thank you so much Randy
My custom rom is
AnasDroid_V1
See sample picture in https://www.facebook.com/anucha.chai...61982807269252
-Base rom from my tablet (Windows N90II). Jelly Bean 4.1.1
-Rooted
-Default Thai language
-Launcher from PIPO U3 (Mod wallpaper), at home screen can not rotate to portrait but another is OK
-init.d supported
-internal memory 2.22 GB
####For no have CWM recovery download from
Note:
====1.After finished (flash rom) It will reboot to CWM recovery.
Select "-wipe cach partition" and "-reboot system now".
====2'My rom is setting Default in Thai language.
setting your language and Time zone.
====After reboot go to setting=>storage=>click "NAND FALSH" to format.
====or see notification in systembar it will show damage SDcard select it to format.
====It will 2 app to show stop working to solve it go to Setting=>Security=>select unknown sources
====open Root Explorer app and go to /system/app/
==== select Archos.apk to replace install =>done.
==== select Term.apk to replace install =>done.
****** I not sure parameter file is compatible on Xtron tab.if not, to use Randy's parameter file
replace in folder ROM and flash again *******
####For have CWM recovery download from
Note:
====1.Add folder "ClockworkMod/backup" in sdcard or external_sdcard
====2.Unzip AnasDroid_V1.7z then you have folder "AnasDroid_V1"
====3.Copy folder "AnasDroid_V1" to ClockworkMod/backup
====4.Reboot to CWM recovery. Use Holo Reboot app select
Reboot recovery=>OK=>Grant(superuser)
====5.After Reboot to CWM recovery select "-backup and restore" => "-restore".
If you locate rom in external_sdcard select "-restore from external_sdcard"
HoloReboot.apk
Good luck and happy to play
--==PS. If my rom work fine in Xtron tab, I will share more custom rom==--Last edited by Anucha; 09 October 2013, 22:30.
Hi to all.
I have tablet that is re-branded Xtron (it is called Vivax 7150). Just to inform you, these tablets ARE NOT 100% compatible with Scopad0718 or Cube U9GT4 (camera doesn't work if you flash these rom's). There are some wonderful rom's for Cube U9GT4 (my favorite is BaBymild V2) so if someone could fix camera part, it would be perfect solution for our tablets.
Anyway, you are free to try any rockchip 3066 rom, it is simple process using http://www.freaktab.com/showthread.p...s-v3-5-Drivers , but you should previously root your tablet ( http://praveenmax.wordpress.com/2013...ng-lava-xtron/ ) ant use cwm to backup stock firmware ( http://files.androtab.info/rockchip/.../U9GT4_CWM.zip ).Last edited by vivax; 21 October 2013, 11:30.
Are you have stock rom or backup stock rom?.
up load for I see it to fix camera. maybe it work for your tablet.
There are currently 1709 users online. 1 members and 1708 guests.
