Lava Xtron without HDMI
Here is link to download
AnasDroid V.2b update1
**unzip file in PC
**install driver
#How to flash rom
1. backup everything if you want,
2. connect tablet to PC (press vol+)
3. open RKandroidtool 1.35 and follow to see pic 1
4. wait to finish.
#If you want to install CWM recovery
1. connect tablet to PC (press vol+)
2. open RKandroidtool 1.35 remove tik to all item and follow to see pic 2
3. wait to finish
4. Now you have CWM recovery.
good luck.
Anucha
*note : I want for your feedback/report problem to here. thank you.
cyanogenmod for xtron
Just try cyanogenmod 10.1 by oma on xtron non-hdmi.
It works absolutely flawlessly with stock kernel and cwm recovery from androtab.info but with a few bugs as follows
1. Wifi tether doesn't work
2. Camera is laterally inverted.
3. Battery drainage issue in sleep mode though I found a work around which may sound odd
WORKAROUND: play music on your device on repeat mode. Put it to silent. Lock the device.
By this method we get as low as 4% battery drain in 8 hours.
@Anucha
Can you suggest anything about wifi tether and camera problem.
I tried using modules from stock rom but it results in bootloop.
Originally posted by pranjal59 View PostJust try cyanogenmod 10.1 by oma on xtron non-hdmi.
@Anucha
you can try this
edit:
If you lose camera icon in App drawer, to use nova launcher.
long press on home screen >shortcut>Activities>Gallery>camera.
you will have camera icon on home screen.
edit 2:
If not show "Not charging" when you plug in charger.
try this kernel to solve it
edit 3:
Now. I cancel this project (CM 10.1 ) because it have more problem of battery drain is fast and low performance in OpenGL 2.0Last edited by Anucha; 12 March 2014, 06:51.
Originally posted by pradipsoman View PostHow can I swap the internal and external SD memories to store games on the external SD? Is it the same procedure i.e editing vold.fstab?
before edit, must to backup everything in sdcard and external_sd to PC
use root explorer edit as text editor follow this
dev_mount flash /mnt/external_sd auto /devices/virtual/mtd/mtd9/mtdblock9
dev_mount sdcard /mnt/sdcard auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0 external_sd auto
dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_host/usb /devices/platform/usb20_otg/usb
-safe and check permission to rw-r--r-- or 644
-reboot.
-after reboot connect tab to pc erase everything in two drive and copy backup to sdcard and external_sd from PC to tab (already swapped).
*trick and tip*
memory card should format and setting to
File system = fat32
Allocation unit size = select large size, 32 or 64 kilobytes, It make r/w data to fast and reduce lag.
Battery not charging!
Anucha...I tried your v2 ROM on Extron and the battery icon though shows charging sign, the percentage stays at the point of flashing the ROM....It stays at 31% in spite of long time of charging...Any work around?? The ROM is very good. So if you can suggest a solution, I plan to use it...Will the updated kernel that you have provided do the trick??
There are currently 2966 users online. 0 members and 2966 guests.
