all these kernels now have the Frame skipping fix included
thanks a lot to phjanderson for the fix.
here is my overclocked kernels for the MK802-IV or UG007B with Ap6210 WiFi
For this kernel to work you must have a rom that does not have the kernel in the boot partition I recommend this one as it works perfectly http://www.freaktab.com/showthread.p...om-Version-1-0
just replace the kernel with mine
I cannot be held responsible for you overclocking your device and damaging it, remember keep your device cool
All kernels now updated @ 04/09/2013
720p no overclock http://www.cloudstor.es/file/m1_NTU0NA/
1080p no overclock http://www.cloudstor.es/file/m1_NTU0NQ/
First we have moderate overclock available kernels here are
720p 1.7ghz ram 1000mhz
720p 1.7ghz ram 1200mhz
720p 1.7ghz ram 1400mhz
720p 1.7ghz ram 1500mhz
1080p 1.7ghz ram 1000mhz
1080p 1.7ghz ram 1200mhz
1080p 1.7ghz ram 1400mhz
1080p 1.7ghz ram 1500mhz
all kernels in one RAR 720p and 1080p download here http://www.cloudstor.es/file/m1_NTU0MQ/
now we have high overclock available kernels here are
720p 1.8ghz ram 1000mhz
720p 1.8ghz ram 1200mhz
720p 1.8ghz ram 1400mhz
720p 1.8ghz ram 1500mhz
1080p 1.8ghz ram 1000mhz
1080p 1.8ghz ram 1200mhz
1080p 1.8ghz ram 1400mhz
1080p 1.8ghz ram 1500mhz
all kernels in one RAR 720p and 1080p download here http://www.cloudstor.es/file/m1_NTU0Mg/
now we have extreme overclock available kernels here are
720p 1.9ghz ram 1000mhz
720p 1.9ghz ram 1200mhz
720p 1.9ghz ram 1400mhz
720p 1.9ghz ram 1500mhz
1080p 1.9ghz ram 1000mhz
1080p 1.9ghz ram 1200mhz
1080p 1.9ghz ram 1400mhz
1080p 1.9ghz ram 1500mhz
all kernels in one RAR 720p and 1080p download here http://www.cloudstor.es/file/m1_NTU0Mw/
now we have gpu and cpu overclock
720p 1.8ghz ram 1400mhz GPU 800Mhz
download here http://www.cloudstor.es/file/m1_NTU0Ng/
