Besides heat is bad for the cpu life.
overclocked kernel is here for the new Ap6210 WiFi MK802-IV or UG007B
It would be useless me releasing the gpu oc for this stick as over on the other thread here http://www.freaktab.com/showthread.p...is-here/page10 there is only one other person that it is stable for. It just seems like I have got a good stick
Originally posted by sam321 View PostIt would be useless me releasing the gpu oc for this stick as over on the other thread here http://www.freaktab.com/showthread.p...is-here/page10 there is only one other person that it is stable for. It just seems like I have got a good stick
well i just build a custom case from stuff i had laying around so i now got active fan blowing air on the chips (i have heatzink on then to)
i just need a new fan so i can blow air in on both sides of the mk802iv then i would love this OC GPU thingi)
so if you have time i would love to have 2 kernel
1
1080p 1.7 ghz 1000 mhz 800 mhz for testing
2
1080p 1.8 ghz 1400 mhz 800mhz for furter testing if number 1 gose well.
So i am still hoping that it is comming for the AP6210 model witch off curs is newer and maby could be better on here
hmm is it to obvious that i am begging?
test
I have a UG007B with the new AP6210 wifi
I would also be willing to test if you made a 1080p kernel with maybe '780Mhz' gpu
i now use the 720P 1.8Ghz -1200Mhz kernel you have made with passif heatsink (a big dude)
would the higher memory speeds make video playback (1080p movies) & games smoother?
or only gpu OC? btw : the 1080P kernels makes my full HD go crazy fo some reason (popping sounds and green lines !)
Wifi on this device sucks (1080P streaming is not possible , 720P is ok)
I also have a J22 with ap3210 chipset stick , wifi is stable on that one due to 2 external antennas
does anyone know a good mod for the UG007B (MK802IV) Wifi stability?
I'm earnestly praying for it..........
Is your kernel compatible with rk3188? I've got pipo m6 3g with retina display runnin riley rom and kernel with sdk 2. My cpu is locked at 1.6 ghz can OC without an unlocked kernel would really love to overclocked it. Can you kindly give me a link for your suggested/recommeded kernel for overclocking pipo m6 3g
Last edited by neoal; 02 September 2013, 14:33.FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
My Plexi MK802IV mod
http://www.freaktab.com/showthread.p...xi-MK802IV-mod
There are currently 2390 users online. 2 members and 2388 guests.
