This is a simple one this time!
Many thks to gearbest for sending me the device to play
Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Changelog V1:
- Based on latest stock!
- Cleaned lots of stuff...
- Added TWRP
- General optimization and how the ram is used, should better now.
- Permissions fixed.
- Added Xposed Framework
- Custom Wetek WebOs launcher (Many thks to wetek for let me use it)
- - Menu Button is king on this launcher, its used to add remove icons on the main screen, also to remove widgets.
- - Long press on the default icons on desktop you can change them to other apps (White Logos...)
- - Long press on the icons you add to the deskop and you can rearrange them.
- Live Wallpapers, you can control it in "Settings -> Display -> Daydream." ( you guys need to chose "Backdrop" and add a timer, like 5 min etc... )
- Working ATV google remote control!
- Netflix, youtube playstore...etc... fully working
- 4k Youtube support!
- Updated DTV App to the latest one.
- FTMC Build 26.
- Cast working ( May take a bit to work... )
- Added lots of Kl's
- Gapps updated!
- initd.d support.
- Xbox360 wireless Gamepad, original and Chinese clones?!(well it works with my clone adapter...)
- PS3/PS4 gamepad support(only with cable...)
- Fixed auto frame switch in kodi. It only works on FTMC(included) SPMC 16.6.0, on kodi 16.1 doesn't work because is to old(misses a lot of fixes for the new S9xx devices), Kodi 17 its a it and miss this days!
- And other little stuff...
- Dont Update for the latest Netflix App... it will stop working if you do, you guys need to complain to neflix for the stuff they are doing....
- I bet you guys/girls tell me if they are more
- DOWNLOAD HERE SCV1 ROM
- MD5: 4F075C3E9A2B4D7D28FA1B3EFAE50E34
- Open usb burning tool, load the rom and untick erase bootloader.
- 1º - OTG port its the usb port near the sdcard the upper one
- 2º - Press the reset button and add the usb cable and leave it pressed (you need it for step 3...)
- 3º - Release and press again the reset button quickly and then connect the power cord.
- 4º - Flash....
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
