[ROM] Mecool/Acemax KIII PRO SCV1 ("Normal" Android)
    Something is coming....
      Superceleron,
      thank you for this great job even my box is still on trip to me from gearbest.
      I will give a try when it arrives,
      Can't wait
          Well that one is now in here... http://freaktab.com/forum/tv-player-...oid-tv-version
            I have widevine level 1 version, is this safe to install?
              "Netflix, youtube playstore...etc... fully working"
              What does it mean? Is Netflix working in HD using the normal Android TV app? Or the Netflix app installed on this rom is the usual SD phone app?
              Thx in advance
                Hay Superceleron. Installed your tv android version rom 7.1.1 and loved it I have now installed this normal version as I do prefer to alter my launcher and add items I like to my home screen also I can use a different launcher. The Rom works lovely impressed. I noted in your other posting that you were going to make a normal version for the 7... version, hope this is still on the cards and can’t wait for it
                Until then one think is that when I try to install adaway it says “the su binery could not be found or there is no root permission for adaway”
                it says lays in your first page description that this rom is properly routed.
                Any my ideas on this one buddy
                  this is a old android 6 rls, the root should be working.. but who knows now.
                  And yes i did say i will be making a 7.1.2 normal rls, i only still dint had the time.
                    i dont think i routed this one, sorry... to many roms i really cant remember...
                    So is should be a typo on the 1º page!
                    Hi All sorted. I noted you had Supersu on and with an update to this it was all sorted. But thanks for your replay
                    any news on the Normal Android version 7. Nougat
                      Already rooted with SuperSU installed ?
                        Yes it is
                          The remote control repeatedly repeats, going through menu items, how can I slow it down?
                            Great work,how to adjust ir remote speed ? Thanks
                              Hi güys game pad not workjng please update
                                What's the username/password for connecting using smb ?
                                Envoyé de mon SM-N9005 en utilisant Tapatalk
