Is there any way to make HDMI CEC settings lasts over a reboot?
Minix X8-H 5.1.1 , Flashed with ProBox2-ex firmware
To make it work permanent with your remote, enable developer options mode (settings/more settings/ click on about 5 times), exit more settings and then go back into it and developer mode will show up, go into that and disable usb audio. Reboot the minix and your sound will start working fine.Last edited by mrdude; 06 September 2017, 04:38.
Originally posted by eac View PostYes Sir! You did my evening!
I have sound now
So you've quoted my 2nd issue and solved my 1st one.
Can you, by any chance, solve the quoted one as well?
Hi there guys.
Having a look around the forum and came across this thread which was a nice surprise, dug out my long forgotten minix from a dusty loft and flashed the ProBox f/w bringing new life to it, so thanks to all who contributed.
Everything seems fine except the blue led no longer works, apart from a quick flash when the box is turned on. The led worked ok before the flash.
No big deal i know guys but has anyone else had this problem ?
Originally posted by eac View PostYou're not alone, my friend. I have this issue as well, like many others.
Enjoy your new firmware ignoring this little thing. :-)
Trimis de pe al meu P024 folosind Tapatalk
For anyone having problems connecting the minix to their laptop/pc you must have 'usb debugging' enabled, found in the 'developer options'
If you cannot find 'dev options' scroll down to 'about' and highlight 'build number' and hit the ok button 7 times, this will enable it.
If still having problems try using a different usb/otg cable, i tried 3 before getting the minix to connect.
Originally posted by tis View PostEverything seems fine except the blue led no longer works, apart from a quick flash when the box is turned on. The led worked ok before the flash.
Now when you turn the box on the led lights as the ground doesn't need a signal to turn on.Last edited by mrdude; 08 October 2017, 15:51.
AC3 is working on original Minix FW...but i have issues with sound outage sometimes during movie playback(probably heavy MKV file)...
Also no sound at all from Atmos movies...Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
Originally posted by tobenary View PostI can tell you that I tried to play AC3/Dolby Digital files from Kodi w/o success.
Going to sell this box to someone...
Has anyone tried the official lollipop RC release for the x8h plus? I've tried both the official and Finless' rom based on it and they are both infinitely outperformed by my x7 with wasser's rom. I don't mean to take away from the work that Finless has done, but he based his work on the official RC release and it is slow as molasses. I haven't bought a minix box since x7(I got this x8h plus for free) simply because of the terrible software support by minix. Anyone know if installing the Probox2-ex firmware yields better results? Thanks
There are currently 2556 users online. 1 members and 2555 guests.
