Scishion V88Plus 4k won't start and RKBatchTool fail
Hello sorry for my english. But i try to explain. My V88 plus rk3229 won't start. Light is always red. I try to use RKBatchTool 1.8v and install new Firmware (1978252 SCISHION V88 plus Mini PC New Firmware 20170210_v004) but when i press upgrade RKBatchTool write fail ( PREPARE IDB FAIL ) i tried and other program ( AndroidTool_Release_v2.3 ) also i installed drivers DriverAssitant_v4.5. help me with this problemYou may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosTags: None
Originally posted by zipasi View PostHello sorry for my english. But i try to explain. My V88 plus rk3229 won't start. Light is always red. I try to use RKBatchTool 1.8v and install new Firmware (1978252 SCISHION V88 plus Mini PC New Firmware 20170210_v004) but when i press upgrade RKBatchTool write fail ( PREPARE IDB FAIL ) i tried and other program ( AndroidTool_Release_v2.3 ) also i installed drivers DriverAssitant_v4.5. help me with this problem
If still not working you have to enter MaskROM mode by shorting some EMMC pins on the chip and open the box.
with AndroidTool when i press EraseFlash also write PREPARE IDB FAIL. what Pins shorting? i found photo on internet these pins need to shorting https://img15.hostingpics.net/pics/8...hortcutV88.jpg?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hi, if I could leave a recommendation here, I would never use AndroidTool, if you are a beginner, it is best to avoid this tool. It's not that I know more than the developer, on the contrary, I'm a noob, but I've done about 20 firmware changes in my current Box, and I've already made another hundred flashes of my old Android phones and I have a little experience .
AndroidTool is for the Rockchip SoCs, the same as the SP Flash Tool is for the MediaTek SoCs. Truly the best and software for device recovery, but, on the other hand, is the most dangerous. When you use wrong options, many bad things can happen and if you do not know a difficult sketch efficiency method, it means that your device will be lost.
Missing on the device panel was not for everyone, some end up not getting and getting worse. I have seen in one of the older forums that it is possible to make a microsd card with boot. It would be a better option to reduce the frame, but I do not know if this option works for RK3229. Then I'll try to set one up for testing, if it works, I can post it on the forum for the guys to redo.
Well, let's conclude from the subject, I really wanted to be able to help the guy who put his device on bricks, but I think he already erased a difficult partition. What I can say is that sometimes it happens that the USB port disconnects for some reason, the time it expires and gives this error in RKBatchTool, it may also happen that the "Restore" option does not work.
Maybe this error suggested after blinking from Firmware 6.0 to V88 and then blinking unsupported firmware. If you were just using the "Restore" option, leave it away, it stops blinking from Android 6.0 to V88. Maybe the reason for this is the Boot version of this firmware, which is 2.32, the majority is 2.31.
When it happened to me, I was really scared, but I already have a little experience on it, after a few attempts to get red status, I used the "update" option and the flash was fast. Sometimes you get into a few bugs, maintain patience, uninstall and reinstall the drivers, replace the USB cable or simply try again, it may be the solution
Originally posted by zyp View PostI have the same problem.
Try EraseFlash in AndroidTool v2.35 and then Upgrade/Update, don't use RKBatchtool.
Hi zipasi
If you have already tried everything, already changed the base firmware that is using, and nothing worked the ideal is to go to MaskROM mode, guided by mo123, I attached a Ugoos tutorial for you to take a look, but attention, DO NOT USE the same ones Pins. To avoid bigger problems you can post the photo of your EMMC here and someone, maybe the mo123 will talk about which pins make the short.
Good Luck.
Originally posted by Novato View PostDid you make the circuit on these pins? Who told you these were? Does your Box turn on any LEDs?
There are currently 2037 users online. 0 members and 2037 guests.
