Scishion V88Plus 4k won't start and RKBatchTool fail
    It is my Box. What FIRMWARE need for this box Scishion V88 plus 4k? maybe it need other Firmware?
      Originally posted by zipasi View Post
      i Didnt make the circuit on these pins photo is not very good. my box dont turn on any LEDs only red. i dont know what hapened. i came back home after job and box didnt work. Now when i connect box on RKBATCHTOOL it is blue on Connected device. A few times light was green but i dont know how i did that. Click image for larger version
      Hi, I understand, it really happens with these boxes, if the Red LED turns on is not the worst of cases, still back. The important thing is to know which pins to use to make the circuit, if you do everything carefully, your box will be working again.
      Not if you read what I wrote yesterday, but on the forum, in the development area has a tool to write ROMs directly in the microsd to work in devices with Rockchip, option of update exists the option of Boot, that is it works as a pendrive Or cd bootable in Windows.
      According to the comment of a develop, this option would be an alternative to the option of making circuit in the pins, I do not know if it will work on your device, but maybe it is a good option to have a look at this tool. If I find the post here in the forum post the link for you.
        My Box on the outside is an MXQ-PRO 4K, but inside it closely resembles a V88, mainly because it has the AV and SPDIF connectors in yellow. I use firmwares like A95X R1 Android 5.1.1, Ugoos UT6 1.2.0 Android 6.0 (although it is the best firmware does not have bluetooth chip support and well to Infrared Control), I also already test this for V88 / MX4 ​​Android 6.0 and I did not like it very much . There are others that sometimes work, some get stuck in the boot, others just turn on the red LED. Here I recommend the Firmware A95X R1 Android 5.1.1. Regarding this photo there, the ideal would be to be able to exercise all the details in the zoom, try to get a borrowed phone and send the photo.
          More photo to Novato
          You may only view thumbnails in this gallery. This gallery has 4 photos.
            zipasi,
            I have the same device as you, here's the correct firmware (rk3229_6.0_MX4V_V88_PLUS_RTL8723cs_zhongx_20170518 _V008_Spectek) https://mega.nz/#!j19WEDTA!XSCGw-El8...wBQX5-rzOPN8s4 .
              I had not looked well, yours is the V88 Plus, the firmware should be another one because of the RAM, I attached a link from Gearbest, download at the end of the tutorial. With regard to pins, I would really like to tell you what to do the short but I am not an expert on that, you will need to wait for someone who understands better.
                While I wrote Anthony also posted a link The firmware, that's great, more options ... hehe
                  HI. with this firmware rk3229_6.0_MX4V_V88_PLUS_RTL8723cs_zhongx_20170518 _V008_Spectek my box start work but now it stop on android logo.
                    If you using rkbatchtool make sure you select the restore option not upgrade, if you using Android tool then erase it first.
                      This is already a lot of progress, how did you manage to do the flash? Did you circuit the pins or just tried to do flash and got it? Did you use which tool? Tell us details, your post will help others with the same problem as you.
                      On the firmware, try also the Gearbest that I sent the link, sometimes some ROMs, I do not know why they get stuck in the logo (before bootanimation). Sometimes it happens to me, it may be some incompatibility of Boot.
                      ​​​​​​​Only test the firmware you are sure is for your device.
                        i write you how i do the flash.
                        1. i put usb cabel to pc
                        2. i start program AndroidTool_Release_v2.35
                        3. then i select img file of FIRMWARE
                        4 i circuit the pins and put usb to tv box and when AndroidTool Found one MASKROM Device i dont circuit the pins
                        5. Then i EraseFlash and get Prepare IDB Fail
                        6.
                        in few times i didnt get Prepare IDB fail and Flashig was almost done but then was some fail after download firmaware or testing firmaware. But then after reseting tv box the light was blue and tv box stoped on android logo.
                          Well here's another firmware that also works on MX4V board https://mega.nz/#!ILgVXQ7J!QrkZNxo9v...nbZUqTEAGclbQU . This one confirmed working on mine.
                            6.
                            Thanks for replying ... From the image above it seems that this firmware is not compatible, or that there are errors in reading the internal memory, probably by the methods used or by incompatible firmware. But I know this tool well since I have never used these functions. The 4th item you described I could not understand well, maybe it was a translation problem (My native language is Portuguese). When you test other firmwares posted here, tell what happened.
                              Hi i try anthony96 firmware rk3229_6.0_box_MX4V_RTL8723CS_RTL8703BS_SpecTek_fl ash-update_20170502 and get fail. it is on photo
                                So far I do not understand you did the circuits on the pins or not. From previous images it looks like something wrong ah at EMMC. If you do not know the pins yet you can ask in the area of ​​developers, there will have more views
