I got my device 2 days ago. It was the generic H96 Pro+ 3/32gb with DDR4 ram S32 - V3 9377. Pictures are attached.
It came pre-installed with android 7.1.The installed build it came with was:
aml_7.1_s912_q9377- H96PROPLUS_mac-20170422
Now the box turned on and everything worked except when I tried connecting it to the wifi it kept disconnecting. Then I read that there is a maleware in the forum. Downloaded Malewarebytes and it detected the wireless updated bug and deleted it. But this didn't do much. We have 2 wifi connection and on one it would connect and stay connected but wouldn't get much speed. This router is about 15 feet away from the H96. The other was 8 to 10 feet away and that is the one that kept disconnecting. Â*It's a wifi repeater so I put it inside my room and then it wouldn't disconnect. The connection was stable but the speeds again were super low. On both I got 0.5 to 1 mbps. While on the Laptop and my Phones at the same distance (Dell N5520, Note 4 and Moto xt1060) I got 7 to 7.5 mbp's on speedtest(I live in Pakistan and that's the kind of speeds we have). So it can't be the routers as the wifi works perfectly on the other devices.
I wanted to know if that is a normal thing for this box. Does it perform well for anyone whose router is more than 10 feet away from the device. Because without the wifi I can't do much with the box. It just is a worthless device then. So I hope this is just an issue with the one I got. I have returned it as I have a 7day return on it. I am gonna ask for a replacement device and give the box one more go.
Please share your experiences, by mentioning the Box model, Build and distance between wifi router and the box.
Also if not this box then what else would you recommend in the same price range or a little higher???
Regards.
Noor666
