Is the RK3368 officially dead?
Originally posted by davzar View PostCan you please suggest the best firmware for Beelink i68g (RK3368 with AP6330 chip)
Inviato dal mio MI 5s Plus utilizzando Tapatalk
http://freaktab.com/forum/tv-player-support/rk3688-devices-aa/beelink-rk3368R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by jit18 View PostIs the RK3368 officially dead?
Android 5.1 and like i see now it will never be updated ...no marshmallow..no cougat...terrible company Leotec...
I would like to update my android tv using a custom rom with rooted and non rooted options...
Can anyone cook a rom for me?¿'...
Or..is there any custom rom available for me?¿?
P.D.:
I wouldn't´t care to donate money to the cooker who helps me to get it...
Originally posted by koes View Post
no updates for the z4 long time ago.
I had some hope that Coolio would continue because he has so exited about his progress but he disappeared suddenly, i hope he is ok.
Shomari wanted to release a new version of his rom also...
So now we are stuck with mo, but somehow he doesn't like our box
Originally posted by WAIKIKI728 View Post
I was thinking the same...i have this:
P.D.:
You can try several of the Marshmallow firmwares online but risk bricking your device if you don't have a backup of the stock firmware and it will also give you a lot of headache to test all the firmwares that won't work correctly.
Same as always no code improvement from rockchip and piss poor gpu support. Been promiced before as always never comes from Rk. Linux on these device sucks because no support at all. You would think they would learn but no even the new chipset 3399 and 3328 in same boat.
Iam glad to see Amilogic kicking the crap out of them.... Was for told by FreakTab founder many moons ago. "BOB" they didnt listen then and are still going down same path. So you reap what you sow.
scooter2014
I can feel the pain when i read those lines you wrote...
mo123
Thanks for you tip.
My Z68 box is dead (mmc) that's why i bought the Z4.
But i must say that the Z68 was the most useless box i ever had, even worse than my first mk808b stick (rk3066)...
Even though i installed a bigger cooler the box was getting to hot all the time even while streaming a movie (720p) and had poor wifi performance.
The Z4 on the other side is not getting to hot even when overclocked and has excellent wifi.
I tried your HPH NT-V8 MM1.3 on the Z4 and it runs fine but it has a big issue, it needs 5v on the otg port otherwise it won't run.
Do you have an explanation for this and Is there any way you could make a fix for this?
Yes i know, but it's still the best rk3368 device!
There are currently 2519 users online. 0 members and 2519 guests.
