Is the RK3368 officially dead?
Originally posted by minixfreak View Post
Can u post the firmware cause I can't find it
http://chinagadgetsreviews.com/download-marshmallow-6-0-stock-firmware-cloudnetgo-cr18s-tv-box.html
But it does not mean that it will work on the Z68.
The board and components inside would have to be the same for it to work straight off.
But if you like tinkering, know how to flash your boxes between firmwares and recover them from soft bricking then you could give it a go.
This the firmware for the Cloudnetgo.
Originally posted by jit18 View Postscooter2014
I can feel the pain when i read those lines you wrote...
mo123
Thanks for you tip.
My Z68 box is dead (mmc) that's why i bought the Z4.
But i must say that the Z68 was the most useless box i ever had, even worse than my first mk808b stick (rk3066)...
Even though i installed a bigger cooler the box was getting to hot all the time even while streaming a movie (720p) and had poor wifi performance.
The Z4 on the other side is not getting to hot even when overclocked and has excellent wifi.
I tried your HPH NT-V8 MM1.3 on the Z4 and it runs fine but it has a big issue, it needs 5v on the otg port otherwise it won't run.
Do you have an explanation for this and Is there any way you could make a fix for this?
Originally posted by BEN001 View Post
link to firmware MMV1.5+Z4 http://4pda.ru/forum/index.php?showt...ost&p=64338721
Thanks for the Link Ben...
This is what the translation in English gives me:
for Z4, assembled ROM V1.5 in one way with the correct resource for startup, the console does not work
https: //drive.google.c...czNWM/view? usp = sharing
works only with additional 5V (ring OTG and USB ports of the set-top box cord or connect to the USB port of the TV, which allows you to turn on and off the console with the TV), for convenience of disconnecting and restarting the console, I use these applications
Acemax AK838 / Z4 RK3368 / EKB368 [Android] (Post BEN001 # 59764781)
To start in normal mode, use a resource (including lack of power just juggling)
5V_resource.img (4.18 MB)
Ok, so if i get it Wright someone modified mo's HPH NT-V8 MM1.5 Rom so that it works on the Z4 Box but with the known 5V "bug".
But what is the 5V_recource.img supposed to do?
Unfortunately the file is offline.. (404).
The reboot apks are also offline..
google disk link:
5V_recource.img corrects fix "bug start TV box" :
https://drive.google.com/file/d/0By2...ew?usp=sharing
use flasher AndroidTool 2.35
apk link:
Thank you for the links...
So this:
https://drive.google.com/file/d/0By2...BNUmczNWM/view
is the original mo123 HPH NT-V8 MM1.5 Rom?
Or is it somehow already altered for the Z4 and if yes then what was altered?
Originally posted by jit18 View PostThank you for the links...
So this:
In the original resource the parameter clocks-init-parenе 0x56 was changed to 0x68
org.
clocks-init {
compatible = "rockchip,clocks-init";
rockchip,clocks-init-parent = <0x30 0xf 0x35 0xf 0x4c 0xf 0x17 0x1f 0x39 0xf 0x21 0x16 0x12 0xf 0x2e 0x56>;
mod.
clocks-init {
rockchip,clocks-init-parent = <0x30 0xf 0x35 0xf 0x4c 0xf 0x17 0x1f 0x39 0xf 0x21 0x16 0x12 0xf 0x2e 0x68>;Last edited by BEN001; 30 October 2017, 08:37.
This is firmware altered for the Z4 with the changed resource, what was altered for start work tv box:
org.
clocks-init {
mod.
clocks-init {
Brilliant.. Who did this?
the most stable firmware mo v1.1 for Z4- mod. Diman 3452
http://4pda.ru/forum/index.php?showt...ost&p=58677199Last edited by BEN001; 30 October 2017, 17:50.
Originally posted by BEN001 View Postthe most stable firmware mo v1.1 for Z4- mod. Diman 3452
There are currently 3622 users online. 0 members and 3622 guests.
