Great job on fixing the jitter issue for this TV Stick!! Installed it yesterday and nothing but sweetness!! Unit doesn't get too hot, using stock PS. ordered another one j.i.c. Everything installed easily, not one reboot. have used it a lot last night and the wife has been watching movies all morning in bed today. Thank you for fixing the MK908, I thought I wasted $75 after seeing the reviews and experiencing the video issue myself. Keep up the GREAT job and I look forward to testing your further work!
UPDATE 8/4/13 - MK908 Finless 4.2.2 Repack-jjhmod with Vsync Fix v1.1 - Download
Great work! MK908, your ROM fix, hard wired ethernet and XBMC is GREAT!!!
I cant get my hard wired ethernet to work with this rom
Originally posted by jetski1963 View PostGreat job on fixing the jitter issue for this TV Stick!! Installed it yesterday and nothing but sweetness!! Unit doesn't get too hot, using stock PS. ordered another one j.i.c. Everything installed easily, not one reboot. have used it a lot last night and the wife has been watching movies all morning in bed today. Thank you for fixing the MK908, I thought I wasted $75 after seeing the reviews and experiencing the video issue myself. Keep up the GREAT job and I look forward to testing your further work!
Originally posted by clone12100 View PostHow do you get your hard wired ethernet to work with this rom? All mine does is turn off as soon as i turn it on. My wifi works perfectly fine and my rj45 to mini usb is showing its connected.
I would also recommend trying my Android 4.2.2 jjhmod v1.1 rom.
If my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
Bricked my mk908
[QUOTE=hoabycsr;83348]what type of adapter do you have? I can make sure whether support for it is available. Hopefully I can just add it to the kernel.
http://www.freaktab.com/showthread.p...ll=1#post83329[/QUOTE
I think I just bricked my device. Im stuck in a boot loop. Any help with getting out of this?
[QUOTE=clone12100;83365]Originally posted by hoabycsr View Postwhat type of adapter do you have? I can make sure whether support for it is available. Hopefully I can just add it to the kernel.
I think I just bricked my device. Im stuck in a boot loop. Any help with getting out of this?If my work benefits you and you want to help out the cause, feel free to
I am using this USB 1gig ethernet adaptor.
Originally posted by MeatHead View Posthoabycs, can you put the screen size slide button in your rom?
ps this is a great rom.
I will see what I can do.
Support for that is already in the rom, just need to figure out how to gain access to it.Last edited by hoabycsr; 04 August 2013, 18:09.If my work benefits you and you want to help out the cause, feel free to
Originally posted by jetski1963 View PostI have this adaptor: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1. It works Great! Just plugged it in and ZOOOM! You have to make sure you turn your wifi on the stick off. I learned the hard way. when playing with it, it killed the whole network, wife was doing school work! bad move.
So it is working now?If my work benefits you and you want to help out the cause, feel free to
Originally posted by blackice55 View PostMy unit is stock on the geekbuying and freaktab image with the robot when I plug it now... do that mean that my stick is already broken?If my work benefits you and you want to help out the cause, feel free to
Check the first post and download the new rom. Thanks for the kind words!If my work benefits you and you want to help out the cause, feel free to
Originally posted by Legitsu View Postso with this can we actually play 1080P 12Mbit/s MKV ?
Couldn't say as I haven't tested that.If my work benefits you and you want to help out the cause, feel free to
There are currently 2029 users online. 3 members and 2026 guests.
