H96 Pro TV Dongle Android 7 Amlogic S912 2/8GB BT4.1 H.265 4K Stick
    Click image for larger version  Name:	1499908677979116.jpg Views:	1 Size:	57.1 KB ID:	656103
    Specification
    Model: H96 Pro
    Type: TV Dongle
    GPU: ARM Mali-T820MP3
    CPU: Amlogic S912
    Core: 2.0GHz,Octa Core
    RAM: 2G RAM
    RAM Type: DDR3
    ROM: 8G ROM
    Max. Extended Capacity: 32G
    Decoder Format: H.264/AVC,H.265,HD MPEG4
    Video format: 1080P,4K x 2K,AVC,MPEG-4,MVC,VC-1,WMV
    Audio format: MP3
    Support 5.1 Surround Sound Output: No
    5G WiFi: No
    Bluetooth: Bluetooth 4.1 + EDR
    Power Supply: USB Port
    Interface: HDMI,TF card
    Language: English,Multi-language
    HDMI Version: 2.0
    Other Functions: ISO Files
    Power Type: Digital Power Supply
    Product weight: 0.2000 kg
    Package weight: 0.2500 kg
    Product size (L x W x H): 10.00 x 8.00 x 4.00 cm / 3.94 x 3.15 x 1.57 inches
    Package size (L x W x H): 12.30 x 10.20 x 5.60 cm / 4.84 x 4.02 x 2.2 inches
    Package Contents: 1 x TV Dongle, 1 x HDMI Cable, 1 x Engllish User Manual
    Geekbuying
    Ahrrr Good to see a new TV stick but would of been nice to see it with 16GB rom
      Yes been awhile since we have had a good STICK...may create a bit of a stir, I see no mention of a remote (normal)
      Fun to control behind the telly..
      One of those BT remotes (Mi remotes) can be found for a couple of bucks if you look around.
        " The remote control is powered by 2 x AAA batteries ( not included )". But I'm still doubtful about remote, no show in package contents list.​​​​​
          Thanks GeekBuying and DHL Sunday delivery...
          We Can have a quick look and the H96 Pro TV Dongle Android 7 Amlogic S912 2/8GB BT4.1 H.265 4K Mini PC
          Pretty Gold Box wife thought it was her, yer right.
          Look inside
          What's in the box
          USb Power and Micro SD SLot
          Vents a good sign (we hope)
          Bit you Stick into the Telly or Short supplied cable
          2 USB ports on the rear
            Now to see what in the Dongle
            Sample Stuckon Heat sink as used in Boxes...this looks Biiger
            Heat Sink removed, Click the image for Bigger
            Other Side, Click the Image for Bigger
            The Bits that make it happen
              I have Jumped onto this quickly as its been a while since i have had a good fiddle with a Dongle type TV Media player
              This is not to bad at all, typical H96Pro Rom 2/8 GB
              Running Android 7.1.1 64bit has root with no SU, upper and lower task bars
              Thats a good start out of the Box.
              So far with its Stock Rom out of the box is doing well as you will see in some benchmarks soon.
              Unit has No remote, you will need some form of a Keyboard Mouse, be it Dongle or BT type.
              No Ethernet and the 2.4GHz WiFi it performing well.
              Temps So far Idle Mid 40C, max seen when testing up in 60c under the pump,
              As seen Heat sink in pretty ordinary and held on with DS thermal tape so room for improvement.
              Unit is Supplied with a 2amp 5v Power pack fed to Stick by USB A to Micro cable.
              As mentioned Chugging along well, very well for what it is.
              Has a version of KDMC (kodi) that wont last long and will install FTMC
              Fired up Netflix for a quick look we know there is no HD 4k etc, but looking ok for what it has.
              Post the results of Info and test soon...
                UI and Some Info, Not to shabby
                Version
                Upper and Lower Task with Option to turn off.
                Click image for larger version  Name:	task.png Views:	1 Size:	235.6 KB ID:	658002
                DRM Info
                CPU-Z
                Antutu Info
                Ram and Storage Truth
                Vellamo
                Geeekbench Compute
                Geekbench CPU
                More Info > http://browser.geekbench.com/v4/cpu/3487109
                WiFi
                A1SD Bench
                Dont think you could go to wrong with one of these little suckers.
                I myself would not leave it behind a TV or Power from TV USB port unless 1.5 ~ 2Amps
                I think it could cause all sorts of Drama with Wifi, keyboard and Heat tucked away,
                TF card, USB drive's etc
                Small Female to Female HDMI adapter and place some place out of the way and easy to get to easy
                On a PC monitor Close to your sitting location etc would be ok me thinks
                For Advertising and running continuous Loop Media etc Ideal Small compact Just beef up the heat sink a bit.
                Nice Little unit Unit Works Pretty well. and for the price a bit of power under the hood.
                Another Quick Test
                With YT playing 1080 and Hooked into BT Speaker all good.
                Click image for larger version  Name:	BT.png Views:	1 Size:	208.8 KB ID:	657997
                Geekbuying
                  Anybody managed to find the display settings for this stick? I would like to alter the screen size as you can with most android boxes but there does not seem to be a suitable obvious display option which is very strange. Any help would be very much appreciated.
                    Hi i looking for to download this android version for wifi 8723bs..... Abybody can helpme, i received from geekbuying support the url, It work but is not compatible whit this wifi realtek.......
                      Appears no stock firmware at the minute on the prowl
                      Whisper tells me there maybe a custom rom
                      not 100% confirmed as yet may take awhile
                      Lets hope a stock can be found soon....
                        I too am searching for the stock for this since i screwed mine up when i installed super su. If i were to purchase another one, is there a way i could extract the firmware from it?
                          New firmware H96 Pro TV Dongle Android 7 Amlogic S912 2/8GB BT4.1 H.265 4K Stick
                          http://freaktab.com/forum/tv-player-...mware-20170826
                            there is a 16gb version at geekbuying, i am sure elsewhere too
                              I bought one of these for my Dad, and he is having issues waking the device from standby. He is using a 2.4ghz wireless USB remote/keyboard and no matter which buttons he uses, it will not wake up if it has gone into standby/shutdown mode. Any ideas? Does this auto shutdown after a certain amount of time or can it stay in standby mode indefinitely?
