H96 Pro TV Dongle Android 7 Amlogic S912 2/8GB BT4.1 H.265 4K Stick
I just bought the 16gig version of this and am awaiting delivery. Want to use it as a travel media player. I am currently using a Lenovo Stick 300 which is surprisingly good but it has an audible fan which can be distracting. Anyway, am concerned about the remote situation. Will a Fire TV Bluetooth remote work? Don’’t care for a keyboard and would like to avoid a dongle. Can’’t use most phones as I won’t have WiFi access.
There is a micro sd slot. It says up to 32gigs but is that because of fat32 or will larger cards work after being formatted as fat32? What about plugging in a portable drive into the usb slot ( can’t on the Lenovo due to power issues)?
Any info would be appreciated.
Originally posted by pmcd View PostI just bought the 16gig version of this and am awaiting delivery. Want to use it as a travel media player. I am currently using a Lenovo Stick 300 which is surprisingly good but it has an audible fan which can be distracting. Anyway, am concerned about the remote situation. Will a Fire TV Bluetooth remote work? Don’’t care for a keyboard and would like to avoid a dongle. Can’’t use most phones as I won’t have WiFi access. There is a micro sd slot. It says up to 32gigs but is that because of fat32 or will larger cards work after being formatted as fat32? What about plugging in a portable drive into the usb slot ( can’t on the Lenovo due to power issues)? Any info would be appreciated..
About external memory, my 128 Go usb key works fine ...
I attempt to use it behind a videoprojector and push my phone content with the miracast service
The dongle detect my phone, but I've any cast after that ... Perhaps linked to the wifi issues ...
-- Fixed with the SuperCeleron's Rom; the native one is a mess --Last edited by ljvd; 20 November 2017, 00:35.
I added external fan (5v USB Noctua type) and pull out internal wifi antenna.Result after (during streaming film full HD): max temp=50 degrees Celsius, signal strength=-50dBm.Result before: max temp=83 degrees Celsius, signal strength=-65dBm.Resonable, I'm very happy.Kodi very flawlesly.Need more?
Originally posted by calinut View PostI added external fan (5v USB Noctua type) and pull out internal wifi antenna.Result after (during streaming film full HD): max temp=50 degrees Celsius, signal strength=-50dBm.Result before: max temp=83 degrees Celsius, signal strength=-65dBm.Resonable, I'm very happy.Kodi very flawlesly.Need more?
Here Ada64 measures -75 - 80 dBm depending of the position, the max temp 73C° , never more due to the freeze
There are currently 2162 users online. 1 members and 2161 guests.
