You have managed to make the IR control work in the firmware [ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV3-ATV 7.1.2 (DDR3/DDR4 - ANDROIDTV VERSION) or [ROM] AlfaWise H96 PRO+ 3/32 and 3/16 - SCV6 7.1.2 (DDR3/DDR4 and 9377 Wifi Chipset) ? I found these firmware's fantastic but the IR control does not work.
Have you installed the KL files on these firmware?
Best Regards
try this, should be able to flash with TWRP
If not manually extract the remote.conf file to right location and set the correct permission.
Sorry for my english...
I've this box about 2 months and it automatically upgraded to last firmware version but there are some problems whit this.
First of all if I install an app I can't see on the menu. I've tryed a lot of times with hard reset too, but nothing.
So I've flashed the previous firmware version and now it works well!
#this file is configuration for each factory remote device
# work_mode 0 :software mode 1 :hardware mode
# repeat_enable 0 :disable repeat 1 :enable repeat
# factory_code each device has it's unique factory code.
# pattern:custom_code(16bit)+index_code(16bit)
# examble: 0xff000001 = 0xff00(custom cod) 0001 (index)
# release_delay unit:ms.release will report from kernel to user layer after this period of time
# from press or repeat triggered.
# debug_enable 0 :debug disable 1 :debug disable
# SW MODE:
# bit_count how many bits in each frame
# tw_leader_act time window for leader active
# tw_bit0 time window for bit0 time.
# tw_bit1 time window for bit1 time
# tw_repeat_leader time window for repeat leader
# REG
# reg_base_gen set value for PREG_IR_DEC_BASE_GEN
# reg_control set value for PREG_IR_DEC_CONTROL
# reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE
# reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE
# reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
# reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME
#amlogic NEC remote
factory_code = 0x7f800001
work_mode = 0
repeat_enable = 1
repeat_delay = 40
repeat_peroid = 39
release_delay = 121
debug_enable = 0
People this is a good flash rom it is up and working on my R-TV S-10 box .. And to my surprise Kodi works on it and the box runs beautifully on it .... It is Android 7.1.1 my box came with 7.2.1.. Thanks a million FreakTab.
Is it the same user interface ?
I love Freak Tab's user interface they did for Alfawise H96. I think it works for this box too.
I hate the stock interface of R-TV
Well since this box uses the 9377 wifi/BT Module this one should work to, and its a very smooth rom. This is the Beelink GT1 Firmware, the one for their QCA9377 Chip, same in yours. You can get the firmware from here: https://beelink-my.sharepoint.com/pe...fIWtLFVL3glZzA
So I got my R-TV S10 a few days ago and just after a few hours of playing with it I opened SU and got the boot loop.
After trying to flash the firmware about 5 times and kept getting the "Get Key Failed" error I contacted the seller and he sent me the following link containing latest firmware (9377_mac_jiami_20171213), USB Burning Tool (v2.1.2) and a quick video guide.
It was up & running in a few minutes!
Find the link below, hope it saves someone alot of time.
To use Google Drive, you need to use a supported web browser.
Learn what a browser is, which browser you use, and how to update to the latest version.
Option 1: Find the update for your browser
To
#abdullah
Does this newest rom have the top notification bar that can be dropped like in a cell phone?
Is the problem by updating Supersu solved?
What more are the improvements?
