Bricked "Mini M8S II" (Clone?) - Looking for help with NAND-pin
Hi I am registered now because I have a problem with my Mini m8s II. A few days ago I tried to start it after a year of not using it anymore, it was stuck on the home screen, I did a couple of resets with the button below but it doesn't work. Now the blue LED does not even light up, if I connect it to the PC with the USB cable it is not recognized, the LED is always off, but the current is there because the TV sees it and the optical input lights up with its red light . I wanted to try to short the nand, but the pins are not exposed. Can you tell me how to do it? I attach 2 pictures.
Hi I am registered now because I have a problem with my Mini m8s II. A few days ago I tried to start it after a year of not using it anymore, it was stuck on the home screen, I did a couple of resets with the button below but it doesn't work. Now the blue LED does not even light up, if I connect it to the PC with the USB cable it is not recognized, the LED is always off, but the current is there because the TV sees it and the optical input lights up with its red light . I wanted to try to short the nand, but the pins are not exposed. Can you tell me how to do it? I attach 2 pictures?
Originally posted by ayeye View PostNo one can help me?...
Originally posted by ayeye View Postthank you! excuse my ignorance but I never did, it must be done with the power on, right?
Originally posted by aidanmacgregor View Post
No, you must short the 2 contacts while connecting the usb cable, after 1 or 2 seconds your pc will detect the device (and assuming you have already pressed start it will start flashing) then you can let go of the short
Originally posted by aidanmacgregor View PostHi, hmm strange, Magisk seems to cause a bootloop as the rom is already rooted, for V7.5 I plan to make a non root version that should work with magisk (magisk did work in older version before pre root) what are you needing to accomplish using magisk?
Originally posted by bhargavh View Post
Now I can only access the TWRP and I have a bootloop , my device is not detected in USB burning tool and SD card burning method didnt work , how do I flash your old no rooted ROM or reflash this ROM ? . Thanks in Advance.
You will need to figure out mask rom mode, upload clear and well lit photos of both sides of your board and will see what I can figure out, you should try my android 9 rom, it is play certified, and not rooted, Based on the official Mi Box Firmware So Very Stable And Fast
thanks in advance.
There are currently 1968 users online. 0 members and 1968 guests.
