[ROM] AlfaWise Z28 Pro 2Gb/16Gb - SCV2
    And another one, this is not a bad chip.
    Many thks to gearbest for sending me the device to play
    Many Thks to my beta tester trebor
    READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
    Changelog V2:
    • Updated some codecs
    • Back to 720p Ui ( Sorry but 1080p Ui is to much for this cpu )
    • Fixed Bluetooth problems.
    • Updated wireless driver.
    • Added SC modded WeOS launcher (menu button on the remote is your friend in this launcher)
    • and
    • Removed Lighthome launcher (is a bit laggy on this box)
    • Updated kernel.
    • Added some missing KL.
    Tweaks V2 Enable Backdrop Screen Saver:
    • 1. Settings -> Screen Saver
    • 2. Inside press "Screen saver" and chose "Backdrop"
    • 3. After that go back and in "When to start" choose the time that you want the screen saver to kick in!
    • 4. Dont touch "Put device to sleep".
    • If you guys want to try it press "Start now"
    Bugs V2:
    • Don't try Magisk, it wont work!
    • Possible more Bugs...
    Changelog V1:
    • Based on stock/and another rom....
    • General optimization, should be smoother.
    • Some house clean!
    • Mem usage lot better now.
    • 1080p Ui
    • Youtube 4K support
    • TWRP 3.1.1 ( thanks Guest )
    • Added Widevine L3
    • Added status/navigation bar.
    • Added power button to navigation bar, single press = sleep, long press power menu.
    • Added Status/Navigation bar auto hide, so dont show anymore on Youtube and other apps!
    • Proper root!
    • Added a setup wizard.
    • Added Lighthome Launcher!
    • Organized some boot scripts.
    • Added lots of kl's.
    • Netflix, youtube, playstore...etc... fully working.
    • Many Gamepads supported.
    • Playstore updated (GMS is updated the 1º time you login to the store)
    • Lots Permissions fixed.
    • FTMC Build 30
    • Fixed RKcodec Playback and fractional HDMI in FTMC. (Fractional HDMI Only works in the 3328 and 3399)
    • Added a few apps...
    • And some other little tweaks...
    Tweaks V1 Enable Backdrop Screen Saver:
    Bugs V1:
    • If BT is connected it may interfere with some Streaming apps.
    • You may have a quick green screen at boot... nothing special ignore it!.
    • Possible lot more Bugs...
    Want to buy me a beer?Download:Install instructions:
    • Search the forum for instructions, is the same as all other rk boxes...
    Where to buy:1º BOOT MAY TAKE AROUND 5 MINUTES MAYBE LESS!
    THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
    USE AT YOUR OWN RISK!
    Enjoy it!
    Updated to SCV2....
    Here is a pic of the new Launcher
      Updated to SCV2....
      One more good job.
      You are the best.
      Can you send me the apk to test on my MX9 pro mini?
      You're firmware don't work on it (boot loop)
        Originally posted by manu_manu4 View Post
        One more good job.
        You are the best.
        well it wont work ok on that one you wont have all the options available that are on this rom..
        Like menu button stops doing is job and that is a important stuff in this launcher, also you lose the ability to change the background etc..
          i need to buy this box to try
            Hi, i have several question for this V2, as i'm a V1 user ....
            1) Is this V2 version with 720p UI able to let Kodi play videos at 1080p ? The stock 7.1.1 and the stock 7.1.2 ROM, with 720p ui are not able to. The V1 is able to.
            2) Can you install and run the OpenVPN Connect application ? With V1, install is Ok but UI is totally blank and you can't configure the client.
            3) Can you install and run the AutoStart and Stay application ? With V1, the Service auto load at startup don't run.
            Many thanks for the great job and the time passed.
              1º Yes because the framebuffer in the video playback is always what the video resolution is, if it is 720p plays 720 if it is 4k is it 4k..., and this cpu is to week for a UI of 1080p.. if you dont mind the menus lag stay in V1!
              2º dunno dint try!
              3º dont know that app, try using the launcher autostart is in the launcher settings this in V2 of course!
                Nice job. Sounds like something to try out!
                I can't read from an exFAT formatted USB stick with my stock ROM, and that is kinda frustrating me.. Do you know if the new ROM and kernel allow it?
                Many thanks!
                • superceleron
                  superceleron commented
                  Editing a comment
                  Dunno i dint try it, but i bet it wont i think for that you need to build a custom one!
                superceleron , I've tried this rom and most things seem to be working fine. Certainly it is much better than the rom which came with the device. One thing I have not been able to get working is the wired ethernet port. I believe part of the issue is that the mac address is 00:00:00:00 . The wi-fi works fine. Any ideas?
                BTW, thank-you for the work you have put into this.
                • superceleron
                  Editing a comment
                  hmm need to check it here!
                Ok. I found the problem. It was my fault. I do not have the right hardware for this rom. I do not have the alphawise z28. I have the other z28. I loaded the other rom and everything is fine. Thanks.
                  good
                    thanks for your work ; can i use your rom on a 2gb/8gb box ??..............
                    • superceleron
                      Editing a comment
                      Well i think yes!
                    I have mistakenly selected wrong wallpaper. How to erase wallpaper (return to default wallpaper) ?
                      same place you changed it, in main desktop little house with the cogwell is there!
                        It has been a while since I worked on Rockchip Android TV box. I just ordered this box and was wondering whether the public rockchip-linux kernel GIT is usable on this device.
                        Vasant
