This is the new firmware from gearbest, and it solve my Z28 Remote control - power problem
[ROM] AlfaWise Z28 Pro 2Gb/16Gb - SCV2
Hello, I would like to change my question because I was able to install it, Grate! On the other Z28 I installed the update: 333_1.05 ____ LUSHEN_XJH_Q7L_V00A7_1_RTL8822BS_lpddr3_Z28Pro_201 70830231210 posted above (# 31) that corrects the problem of Remote Control not turning on. superceleron have something for the same to occur in your ROM? Thank you!!
Hi, I am trying to install the superceleron rom for this box (2/16 GB) but after doing it the box stays stuck on boot screen.
I try several tools for that:
RK_Android_Tool_2.3.9
RockChip_Batch_Tool_v1.8
RockChip_FactoryTool_v1.39
and the result is always the same, the only way to get the box working is to reinstall the stock rom.
any advise on how to solve this issue, I really would like to test this superceleron rom
thanks
There are currently 2088 users online. 0 members and 2088 guests.
