[ROM] Z28 2Gb/16Gb - SCV1
Originally posted by nis81 View Post
Great job!!
About WeOS launcher: I want to know how to modify the media shortcuts (netflix, youtube, .... FTMC).
I do not know how to do it, that eliminates those 5 accesses trying to change them by another application.
Thanks.
Also to move the main screen shortcuts long press on one of them and them you can move them left or right!
Menu button add/remove the main shortcuts and remove widgets, the white icons long press on them (ok button) and it should bring the list of installed apps, then you can change to the app you like....
And on the bottom navigation bar,
The first button starting with the left (they are like two arrows down) so that it serves? I give it to him and he seems to do nothing.
Excuse me, explain me wrong
I am referring to the floating bar, in the photo that I attach the signal.
you can put the link where it is explained how you can transform a copy of the firmware by means of recovery pass it to image file to dump with the RKbachtool in case of emergency.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
I installed the latest version of this software, but the wifi problem still exists, have you found a solution? look video > https://streamable.com/uteol
Is it possible to install the original 'android tv os' rom for this z28 device? or zidoo h6 style split screen ui super...Last edited by GxHero; 22 March 2018, 15:25.
Hi to all
please someone could hep me?
I have the Z28 1/8 I would istall [ROM] Z28 2Gb/16Gb - SCV1 But Mistakely Flashed [ROM] AlfaWise Z28 Pro 2Gb/16Gb - SCV2 while I was flashing it the RockChip_Batch_Tool_v1.8 gave error and cloased.
So I noticed that I flash wrong ROM] AlfaWise Z28 Pro 2Gb/16Gb - SCV2 rom.
after than I reopen the RockChip_Batch_Tool_v1.8 on the pc and than I I press the reset hole with the pin I connected the cable to Z28 but PC doesn't read or see any connection.
so there for what can I do? is this Z28 Garbage now? Or do I have a any chance for to save it? please help about it
thnx.
Originally posted by maliakan View Postok I solve the problem thank you very much... but on the original stock rom wifi doesnot works I tap on the wifi button after a 5 secont its close again. how can I solve it?
There are currently 2742 users online. 4 members and 2738 guests.
