Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
THIS BOX DON'T HAVE BLUETOOTH, THE SWITCH IS THERE BUT DOES NOTHING!
Changelog V1:
- Updated some codecs
- Updated wireless driver.
- Updated kernel.
- General optimization, should be smoother.
- Some house clean!
- Mem usage lot better now.
- Youtube 4K support
- TWRP 3.1.1 ( thanks Guest )
- Added Widevine L3
- Added status/navigation bar.
- Added power button to navigation bar, single press = sleep, long press power menu.
- Added Status/Navigation bar auto hide, so dont show anymore on Youtube and other apps!
- Proper root!
- Added a setup wizard.
- Added SC modded WeOS launcher (menu button on the remote is your friend in this launcher)
- Organized some boot scripts.
- Added lots of kl's.
- Netflix, youtube, playstore...etc... fully working.
- Many Gamepads supported.
- Playstore updated (GMS is updated the 1º time you login to the store)
- Lots Permissions fixed.
- FTMC Build 30
- Fixed RKcodec Playback and fractional HDMI in FTMC. (Fractional HDMI Only works in the 3328 and 3399)
- Added a few apps...
- And some other little tweaks...
- 1. Settings -> Screen Saver
- 2. Inside press "Screen saver" and chose "Backdrop"
- 3. After that go back and in "When to start" choose the time that you want the screen saver to kick in!
- 4. Dont touch "Put device to sleep".
- If you guys want to try it press "Start now"
Bugs V1:
- Don't try Magisk, it wont work!
- Sorry this box cant handle ok 1080p Ui... it gets to laggy and have audio sync problems because of it.
- Possible more Bugs...
Want to buy me a beer?Download:
- DOWNLOAD HERE SCV1 for the Z28 2Gb/16Gb
- MD5: 36E86742B0C70BEB57EDEEF63DCD3A49
- Search the forum for instructions, is the same as all other rk boxes...
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
