Which of these S912 boxes would you recommend?
Title says it all but I would like to have Bluetooth, 5Ghz wifi and a Gigabit LAN port. Also more than 1gb RAM, 2gb should be plenty. Are these S912 boxes worth the extra few quid over the S905/S905x ones in anyone's opinion?"HANDS ARE NATURES FORKS" -RigbyTags: None
Guest
Also, take a look at DRAM and eMMC performance, which tends to be as important as CPU perf. Ideally, you'd also want to get a box with Widevine L1, but those are hard to find.
My personal favorite right now is the M8S Pro (S912), but it doesn't have Widevine L1 like the M8S Pro+ (S905X).
Originally posted by Magendanz View PostAlso, take a look at DRAM and eMMC performance, which tends to be as important as CPU perf. Ideally, you'd also want to get a box with Widevine L1, but those are hard to find.
The 3gb version in the middle?"HANDS ARE NATURES FORKS" -Rigby
#5.1Guest commented01 August 2017, 00:56Editing a commentYes, and it's also available here: http://www.gearbest.com/tv-box-mini-pc/pp_619404.html
There's also a pretty thorough review from Trebor here: http://freaktab.com/forum/tv-player-...fast-lan-bt4-1
Guest
These are both based on a slightly older Amlogic reference board (q201) from the new boxes shipping with Nougat (q20x), but the differences are slight. About the only impact is that you'll get Nougat releases much later (or never at all) and may have to jump through some hoops to get them to work with custom ROMs, which tend to be built on the latest OEM firmware on the latest OS so that they can offer all the latest Android features.
Originally posted by Magendanz View PostThese are both based on a slightly older Amlogic reference board (q201) from the new boxes shipping with Nougat (q20x), but the differences are slight. About the only impact is that you'll get Nougat releases much later (or never at all) and may have to jump through some hoops to get them to work with custom ROMs, which tend to be built on the latest OEM firmware on the latest OS so that they can offer all the latest Android features."HANDS ARE NATURES FORKS" -Rigby
Thanks Guest I'll go with one of these ones so. I had an X96 but I gave that to my dad because he was using an old S805 MXQ and it was really slow and kept having problems.
I'll be looking forward to looking at the custom ROM's and will be browsing this forum again (I've been offline months). One of my favorite things to do on these boxes is try out custom ROM's and experiment.
I'll order one of them tomorrow night."HANDS ARE NATURES FORKS" -Rigby
Guest
Originally posted by steocullen91 View PostIs the M8S you mentioned one of these newer boards?
Originally posted by Magendanz View PostYes, and there are only a couple Amlogic q20x devices (e.g. M8S Pro, KM8 P) available at this point, almost all with firmware developed by VideoStrong. They'll be the first to get any custom ROMs for Nougat.
EDIT: I had enough money in and just ordered it now from Gearbest. Better price anyway but I pressed the EU warehouse instead of China because it'll be so much faster even though it cost €10 more. It was €70.85 including post which is very close to what I said the budget was. What are the odds, it's a sign"HANDS ARE NATURES FORKS" -Rigby
I got that box in the post today. I'm happy enough with it but I noticed when I done a speed test I got 94mb/s and for some reason terrible WiFi like 4mb/s. It's supposed to be 1000mb/s (my Internet is 360) and dual band Wi-Fi. That's probably just my router I'm sure I'll be able to fix that. I should probably try your custom nougat ROM and see how that goes for me. I don't mind experimenting and trial and error, that's mainly what I do with android boxes when I get oneLast edited by steocullen91; 09 August 2017, 17:13."HANDS ARE NATURES FORKS" -Rigby
Originally posted by steocullen91I'm having this one problem that seems to happen on stock and this ROM. The language keeps changing to Korean I think it is? Everytime I reboot it changes and I have to keep changing it back to English.
Inviato dal mio MI 5s Plus utilizzando Tapatalk
There are currently 2748 users online. 1 members and 2747 guests.
