Which of these S912 boxes would you recommend?
Originally posted by gefattern View PostHi Floki ,
Yes you need Widevine for this , i think it has to do with DRM and so on .
There are only some Boxes from here which support that , if you need
this , buy one with Widevine .
good luck
gefattern
Originally posted by clarkss12 View PostAfter about a month and a half, I finally received my M8S Pro Plus, and yes with Mr. Magendanz's mod, i does play Netflix at 1080P with DD+. Made a quick video of it.
https://www.youtube.com/watch?v=oiHwhBrFiK4&t=2s
thank you.
I would recommend on Beelink GT1 Ultimate
Just ordered from AliExpress. The Price is below 60$.
It has 3G RAM and Memory of 32G. The processor is Amlogic S912 Octa Core CPU DDR4. In other words it's a beast for that price.
Here is the link for the Aliexpress Recommended seller:
bit.ly/2fB7knh
Enjoy,
If you can find the Mini M8S Pro (http://chinagadgetsreviews.com/downl...ro-tv-box.html), it's basically the same hardware as the GT1 and is less expensive. And like the GT1 Ultimate, the 3G/32GB config is DDR4.
good luck
gefattern
Hi CanadianDreamer ,
maybe with a mod of a Dev , but i am not a Pro with that .
Look here , Superceleron made a Rom for this Box , good Dev. ,
please ask there once more .
Widevine Support List ??? (really) :
http://freaktab.com/forum/tv-player-...l-android-ddr4
his Rom Description says yes :- Netflix, youtube, playstore...etc... fully working (No 4k Youtube, that is exclusive of ATV rom)
gefattern
Guest
There is a process for burning the Widevine and HDCP keys in USB Burning Tool, but it requires license keys separate from the .img file that are usually only available at the factory. Secure storage in the chipset is also designed so that we can only write the keys, not read them from a shipped unit. It's technically possible for you to flash an L3 box to L1, but you'd need to have a source at the factory who was willing to risk their job to send you the files. Also, the keys are specific to hardware, so an L1 Widevine keybox for the M8S Pro+ couldn't be used on the M8S Pro or GT1.
Originally posted by Magendanz View PostThere is a process for burning the Widevine and HDCP keys in USB Burning Tool, but it requires license keys separate from the .img file that are usually only available at the factory. Secure storage in the chipset is also designed so that we can only write the keys, not read them from a shipped unit. It's technically possible for you to flash an L3 box to L1, but you'd need to have a source at the factory who was willing to risk their job to send you the files. Also, the keys are specific to hardware, so an L1 Widevine keybox for the M8S Pro+ couldn't be used on the M8S Pro or GT1.
gefattern
CD
There are currently 4939 users online. 1 members and 4938 guests.
