Please amend accordingly. Thanks
Detailed installation instructions for H96Pro Plus custom ROM (with most steps applicable to any S912 ROM.)
Here I am here. I haven't played with my H96 for a few months.
I just scanned the ROM thread again, and looks like you now just need to install straight to SCV4 and then apply SCV7A OTA? So where I said:- The SCV2 ROM from the first post of this thread
- The SCV3 update ROM from the first post of this thread
That should read:- The SCV4 ROM from the first post of this thread
- The SCV7A update ROM from the first post of this thread
I don't have time to re-flash my H96 right now. But if someone confirms for me that the above is clorrect, I will edit the OP.
Or yeah, if a moderator wants to take it over, that's cool with me
If You mean Normal Android than it's correct. Coz there is ATV one too and than it is:- The SCV1 ROM from the first post of this thread
- The SCV4A update ROM from the first post of this thread
ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
OK thanks. I updated the guide for SCV4 and SCV7A, and added a note indicating the guide has only been tested up to SCV3. I also added a link to the ATV ROM, with a note that the same method should work but that I have never used it for an ATV ROM.
If anyone lets me know of any glaring errors, I am happy to edit them in.
Please @mention me so I definitely see it.
I will probably be coming back to my H96 sometime in the coming weeks, and at that time I will spend more time upgrading the guide if necessary, including for ATV
I've got the AlfaWise H96 PRO+ 3/16Gb - 3/32Gb GREEN PCB and used the method described to install the SCV1-ATV-A7.1.2-x64-Alfawise .H96.ProPlus image, after the ugrade bar finished the device seem to reset and never got signal anymore.
I've tried the process again but can't get a signal on the TV unfortunatly, when connecting the device with usb to my the usb burning tool does not see it either when connecting with reset button pushed (or without)
Also tried to burn official firmware and load with the sd card but no luck.
Any other options or should i consider it lost?
Originally posted by phywire View PostI've got the AlfaWise H96 PRO+ 3/16Gb - 3/32Gb GREEN PCB and used the method described to install the SCV1-ATV-A7.1.2-x64-Alfawise .H96.ProPlus image, after the ugrade bar finished the device seem to reset and never got signal anymore.
It may be coz Your variant of H96 Pro Plus is not supported? That it is 3/16, 3/32 or 3/64 doesn't mean tat it will work. It works with most of H96 Pro Plus, but not all of them.
Than You may hard bricked Your Box and only fix is shorting memory's pins and reflashing the Box.and onlyALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Hi. I have problem with instalation GREEN PCB SCV4 IMG 7.1.2.
When i hold reset button and then put in power suplly, only for 1 second apear "Upgrading" on screen ,and then signal to TV is lost.
What is wrong.
HELP!
I don't get the "upgrading" logo or screen after I do a hard reset. All I see is the usual Android screen eg. Boot to Bootloader, Wipe Cache, etc.
I think I need the OEM stock ROM because installing either green or blue .img files won't load even after selecting to install from .EXT. I get package not found. My OEM version is Amlogic/q201_9377/q201_9377 7.1.2/NHG47L/20170830Last edited by Noobi90210; 09 October 2018, 02:44.
There are currently 3345 users online. 2 members and 3343 guests.
