Detailed installation instructions for H96Pro Plus custom ROM (with most steps applicable to any S912 ROM.)
I have the box, described here:
as "3/32: (made 09/2017) ZH version Q9377, this time with the designation ZH-01-S912-TVBOX-V.3.0"
I tried to apply this thread's procedure to SCV4 and OTA SCV7A from
that should be possible, right?
but the process gets stuck on Step 5/5: the Upgrading bar proceeds to the right within ~10 seconds and then stops. No further progress, no messages, no reboot, no nothing.
I then unplug the box and power it again, and the standard firmware comes up, unchanged. (at least nothing is broken).
any ideas on what's wrong here?
Regards
sthones
hello, thank you very much for this tutorial, however being a novice in this area I think I understood until step 5 using img SCV2, however this one is call SCV1 green or blue, is that correct?
Step 6, is the OTA file used to update the box to version 7.1.2?
Thank you in advance for your help
You have to know that Android TV is not some kind of theme or mod for "normal" Android. It's different OS, so they are not "interchangeable". Still they're very similar as they base on same sources.
So depending of which OTA You have in mind, there is.V4A OTA for ATV version (SCV4A-ATV -> SCV1A-ATV) and V7A OTA for Non ATV Rom (SCV4 -> SCV7A).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
As far as I thought, there is no, official or not, firmware.
However here seem to be one for Wisdom: https://mega.nz/#F!8qhRRaYJ!2ZA3VLjvLT6wg0IwsTF27g
So it may work for You.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Hi, I reached the step to update the box with the sd card. However, the andoid logo is grey in color and it just stuck in that upgrading screen forever. Photo attached.
My box is green pcb and I used the scv4.
Any advice will be very much appreciated. Thanks.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 2239 users online. 3 members and 2236 guests.
