you can use the 1.37
just browse to the .img files manually then.
thats why its not work ,the cwm file for you.
you must flash the rom first trough pc.
after that you can always use the cwm rom zip for reflashing.
or if i make a whole new update .
in my snakerom folder you have a folder named ''alternate reboot''
open the tool in that folder.
its a flashtool.
connect now your stick on the tv and on your pc.
in the settings off your stick take connect to pc.
you will see that the tool reconize your stick.
click now on switch.
the stick wil reboot to flashmode.
and the number 1 square in the tool is now green instead off pink.
now open the normal flashtool .
and you wil see that the tool says found rkandroid rockusb.
So I'm not entirely sure how I got it to finally work the other way, but it did. I was able to connect to my computer and flash the files, (used the 2gb parameter) AWESOME. Anyway, getting ready to plug it in to make sure that it works. Also, the driver list when it rebooted seem to be longer. Although, the right now I get this Rockusb Device in my device Manager, this is after I tried to install a driver for the RK3066 that was showing up with out any drivers. But it said it ran into an encounter before it finished. The device wouldn't restart or something. I hope you can make heads and tails out of what I'm saying. Anyway, thanks in advance.
1 thing @ a time.
sow you flashed the device succesfully with the pc now.
did you erase idb first?
you say the device wouldn't restart ?
where on the pc or on the tv?
update on stability for the latest factory firmware customed by snakekiller i was the first to install firmware update today was the first issue i had yet i left dolphin browser open over night and the unit was slow i was able to with delay choose reboot and it did withouth pulling cord so there you go more stable than most windows laptops! didnt have to power cycle or anything very good work snakekiller oh and yes i use only this device for daily computing and watching of streaming tv and mkv over nas server movies also i have been playing shadow gun dead zone (free 3d first person i use logitech wireless rumble pad joystick on) and the new ds emulator playing new super mario damb good show!!!
Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
Yes we have the same.
I have also no reset button
You must short pin the 2 dots next to the nand chip.
Then when you connect the device, you are in the maskrom mode.
I upload the picture tomorrow ok.
Because its very late here.
You are AWESOME!!! Ill be trying this when I get home tonight. Currently at work.
ok
you must short pin the 2 dots.
and when you holding it you must connect the stick too the pc.
and the tablet will go to maskrom mode .
i use it every time when i test stuff ,and the stick won't boot.
when you are in the maskrom mode the only thing you must do ,is check the loader in the flashtool.
thats all.
Update
I use a Logitech rumblepad 2 wireless (USB dongle) with my mk802iiis BT for emulators and game pad compatible games!
I wanted to get my ps3 sixaxis controller working tonight with no success!
I installed the sixaxis controller apk v0.6.5 and it works just like my phone and nexus 7 takes over Bluetooth and sits at listening for controllers.. I have 2 ps3 controllers that work on my other androids why does the pairing not happen even if I use the in program pairing with USB it changes it Mac to the right one but still no connect! Do I need a special file or what as I have seen youtube videos with people not having any problem at all connecting to this device
I also tested the bluetooth and it worked with my jabra head set no problem and my ultimate ears Bluetooth jam box speaker and it played music just as well as it does on any other android I have
im test the default rom in the next days and see if bluetooth works also on my device.
if it works here, i look for replacing the files in the custom rom.
thx for the upload.
