Why does ftmc remove the brightness setting from the settings menu during video playback.
I had to switch from kodi Jarvis 16.1 due to krpyton not being functional on my current android box. I was told to use ftmc. The problem is theres no brightness setting, even when i changed the systm menu to advanced. Is there a version of ftmc out there that has a brightness setting?Tags: None
Probably best to post the question on the FTMC thread.
http://freaktab.com/forum/tv-player-support/general-tv-player-dicussions/xbmc-talk/575588-ftmc-jarvis
I did see the same question did come up in a topic regarding SPMC and the advice was to disable Mediacodec(Surface) to enable the brightness settings, although I have not checked this myself in FTMC.
There are currently 2022 users online. 1 members and 2021 guests.
