adb push su /sdcard adb push Superuser.apk /sdcard adb shell su cp /system/xbin/su /system/xbin/su.bak cp /sdcard/su /system/xbin/su chmod 6755 /system/xbin/su cp /sdcard/Superuser.apk /system/app/Superuser.apk chmod 777 /system/app/Superuser.apk exit exit adb reboot
Nextbook 8 HD NX008HD8G Comes with shell root.
I just got one of these and while reading different threads on ways to root this I was messing around in adb shell types su and got the prompt so all I did was use the su and Superuser.apk from motochopper and did this.
Code:Tags: None
Need Stock /system/media/bootanimation.zip for Next8HD8G NX008HD8G
Can anyone provide me with the stock /system/media/bootanimation.zip for the Next8HD8G NX008HD8G?
I need it to finish my flashable stock rom.
Thanks!
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostCan anyone provide me with the stock /system/media/bootanimation.zip for the Next8HD8G NX008HD8G?
Thanks!
ShaunMT
Here you go. Any tweaks or totally stock?Attached Files
Originally posted by Rabid1 View PostHere you go. Any tweaks or totally stock?
Totally stock at first. I think everyone needs a way to return to stock configuration.
After that, I'll start working on some sort of custom rom. Not sure if it will be a modified stock rom, something AOSP or Cyanogen based, or some other port. Might take a poll to see what people want.
ShaunMT
I hve been struggling with editing the boot.img to set ro.secure=0. it says it us a uImage but it always hangs at the unpacking stage. I always get this error. let me know if you have any luck.
Code:>>> boot.img extracted to Image unlzma: Decoder error >>> Image unlzma'd to Image-ext -E- No CPIO image found in Image-ext. ./unpack-uimage.sh: 101: cannot open ../initramfs.cpio: No such file initramfs.cpio extracted
Originally posted by Rabid1 View PostI hve been struggling with editing the boot.img to set ro.secure=0. it says it us a uImage but it always hangs at the unpacking stage. I always get this error. let me know if you have any luck.
Originally posted by silver9990 View PostJust tried this method & it didn't work, I still don't have root access. Anyone have any ideas?
What method are you referring to? The in the first post of this thread?
If it didn't work, what went wrong?
Most, and possibly all, current Amlogic based Nextbooks can be rooted with Cydia Impactor.
There is also a modified recovery and flashable root package for the Next8HD8G located here:
http://www.freaktab.com/showthread.php?6674-Amlogic-Next8HD8G-%28NX008HD8G%29-Modified-Recovery-Stock-Rom-amp-Flashable-Root
Originally posted by shaunmt View PostAm I correct that we are talking about a Next8HD8G?
The method described in the first post here has a few errors to begin with but after a little work I was able to get everything seemingly working but when my tablet booted back up I still didn't have root access.
Originally posted by shaunmt View PostThere is also a modified recovery and flashable root package for the Next8HD8G located here:
http://www.freaktab.com/showthread.php?6674-Amlogic-Next8HD8G-%28NX008HD8G%29-Modified-Recovery-Stock-Rom-amp-Flashable-RootNextbook NX008HD8G - Rooted
When I tried this method my tablet rebooted into recovery as expected but it aborted the installation, after that it just sat in recovery mode until I chose the option to reboot.
I've never tried the Cydia Impactor method either, but many people have reported success with it.
When using the flashable root install that I provided the link to, you need to unzip the recovery download and place the uImage_recovery on your external SD card. You DO NOT unzip the root download.
If it aborts the installation, you've either booted to the stock internal recovery instead of the modified recovery on the SD card or the root .zip file is corrupted and needs to be downloaded again.
Well, part of it was my own stupidity as I forgot to extract the recovery image from the zip file.
Now the problem is that it's still aborting, unfortunately I am unable to get this thing to reboot into recovery using the button method so I had to use adb but I'm not sure if that forces it to use stock recovery so I'm not really sure where to go from here other than to try Cydia Impactor.Nextbook NX008HD8G - Rooted
Originally posted by silver9990 View PostWell, part of it was my own stupidity as I forgot to extract the recovery image from the zip file.
Originally posted by silver9990 View PostAfter doing some more research it appears I was using the wrong button combo, I finally got it to install the root package & now it finally says I have root access.
Thanks for all your help.
I'm not entirely sure that the button combo is the same on all Nextbook models...Freaktab Rom Developer
There are currently 1797 users online. 0 members and 1797 guests.
