Nextbook 8 HD NX008HD8G Comes with shell root.
Originally posted by shaunmt View PostAm I correctrecovery updlking about a Next8HD8G?
What method are you referring to? The in the first post of this thread?
If it didn't work, what went wrong?
Most, and possibly all, current Amlogic based Nextbooks can be rooted with Cydia Impactor.
There is also a modified recovery and flashable root package for the Next8HD8G located here:
http://www.freaktab.com/showthread.php?6674-Amlogic-Next8HD8G-%28NX008HD8G%29-Modified-Recovery-Stock-Rom-amp-Flashable-Root
ShaunMT
Originally posted by Richardbuen1 View PostI tried this method but I ran into an issue while trying to download from plays tore I noticed it wouldn't install any apps can some one explain in detail what to do while in the 3e recov ery
Can you give an example? What were you trying to install and what error message were you getting?Freaktab Rom Developer
Originally posted by shaunmt View PostYou shouldn't have to do anything but flash the .zip and reboot.
I have downloaded both the moded uimage and the zip saved them to my external sd card pressed the power and vol+ button to get into the recovery mode frome there is says
reboot now
update from ext.
update from adb
etc (something)
etc (something)
etc (darkside)
so i updated from ext then rebooted after that it has me set up the tablet when i attempt to download root checker it say's downloading but doesnt seem to ever finish or install
Originally posted by Richardbuen1 View PostI have downloaded both the moded uimage and the zip saved them to my external sd card pressed the power and vol+ button to get into the recovery mode frome there is says
reboot now
update from ext.
update from adb
etc (something)
etc (something)
etc (darkside)
Have you tried wiping data and cache?
ShaunMTFreaktab Rom Developer
Issue with external SD Card/storage settings
shaunmt,
I have a Next8HD8G, to which I just flashed the stock rom and the root package using the modified 3e recovery (all found here: http://www.freaktab.com/showthread.p...Flashable-Root). Now, I am unable to access the external SD card I have. When I put it in or remove it, I do get the notification, but when I go to storage settings, I get 'Unfortunately, settings has stopped'. Also, when I use ES File explorer, it says the SD card is unmounted. Do you have any idea why this is happening, and more importantly, what I can do to fix this? Please let me know when you can. Thank you.
Remove the external SD Card
Boot into stock internal recovery
Wipe Data (Twice)
Wipe Cache (Twice)
Reboot, verify Data and Internal SD Card mount correctly
Reinsert External SD Card
Verify External SD Card mounts correctly
If not...
Wipe Data (Twice)
Wipe Cache (Twice)
Wipe Media (Twice)
If not...
Reformat the external SD Card on a comptuter
If it still won't mount...
Reflash the ROM
Wiping usually solves this problem, although it does not always work on the first try.
Originally posted by shaunmt View PostThis is a common and frustrating problem. Here some suggestions to correct the issue:
Wipe Data (Twice)
Wipe Cache (Twice)
If not...
Wipe Data (Twice)
Wipe Cache (Twice)
Wipe Media (Twice)
If not...
Reflash the ROM
ShaunMT
Oh, one more thing. Can this rooted OS handle the Xposed Framework?
Originally posted by jateed View PostThat did it. I had to wipe the media partition too, but it reads it perfectly. Thank you so much for all your hard work ShaunMT. Now, I just need to remove all the darn bloatware this thing came with.
There are currently 5967 users online. 1 members and 5966 guests.
