welcome feedback.
W95 with S905W will come soon!
hi all.. i have this tv box W95.. first day workig perfectly but in second day wont start.. only screen "please wait" and wont start launcher.. installed only youtube and facebook messenger... please how to factory reset this box?? on bottom is button for "toothpick" but i dont know how its works?
please help.. thanks..
//edit: preoblem solved... connecting to pc and flash worked..Last edited by Frozy82; 10-08-2017, 13:32.
Originally posted by Frozy82 View Posthi all.. i have this tv box W95.. first day workig perfectly but in second day wont start.. only screen "please wait" and wont start launcher.. installed only youtube and facebook messenger... please how to factory reset this box?? on bottom is button for "toothpick" but i dont know how its works?
btw, which spec do you have? could you show us SN on the bottom case? thanks a lot.
spec 2/16..... SN 905WBSLG40397
last question... how to unroot this device? some apps not support root,,,
thanks
try
1, Install ES file manage browser, and open root browsing mode.
2, Delete "su" and "daemonsu" from "system/bin" or "system/xbin“.
3, Reboot the device.
some end users write to us about how to flash W95 box. we are going to release instrucstions in AZW W95 section today to solve it, anyone who need it, please check http://freaktab.com/forum/tv-player-...-flash-w95-box.
Recently, we got some feedback from Internet about how to update firmware without erase data, you may refer to below steps:
1, Format TF card or MicroSD card to FAT32, and copy card IMG(***.zip) to root directory of the card.
2, Insert TF card or MicroSD and enter to system.
3, open "update&backup', select"***.zip" IMG which you keep on SD card, DO NOT SELECT "WIPE DATA" and "WIPE MEDIA", then click update.
This way also suit for other AZW made Amlogic TV box, like Mini M8S II, Mini M8S PRO, QII etc.
We keep updating upgrade information on this section, please pay attention if you have interests.
http://freaktab.com/forum/tv-player-...-flash-w95-boxLast edited by AZW; 10-19-2017, 09:45.
Originally posted by AZW View PostRecently, we got some feedback from Internet about how to update firmware without erase data, you may refer to below steps:
There are currently 2678 users online. 4 members and 2674 guests.
