update error 0x10105002 gt1 ultimate
    I have a bellink gt1 ultimate g912 (wifi 9377).
    The stock firmware on board was 311, I update to 313 by ota.
    The box works regularly but now I want update to android 7 and I will try the custom firmware. I download this firm ware https://beelink-my.sharepoint.com/pe..._NWz38E5fpMOq0.
    I try update by USB_Burning_Tool (I try 2.07.2, 2.0.8 and 2.0.9), I change 2 pc and 2 usb cable but but I can not upgrade the box.
    I follow this instructions: https://www.youtube.com/watch?v=m8ch...ature=youtu.be
    I have always this error (to 2%):
    [0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
    The box work regularly
    Help me please
    1st you have to flash 7.1 stock firmware and then you can install custom firmware 7.1
    Enviado do meu SM-N910F através de Tapatalk
      ( in my opinion. ..)
        If you flash both stock firmware I think you don't have problems
          Uncheck erase bootloader
          Very important
            Use the usb port beside microsdcard
              Thanks for help
              I am trying to flash this firmware https://beelink-my.sharepoint.com/pe..._NWz38E5fpMOq0.
              I use the usb port beside microsdcard but the process stopped always to 2%, also when unched erase bootloader
                Select the .Img
                Select Start
                Reset button and insert the usb cable
                  Reset button and insert the usb cable, do I have to do it right?
                    Try
                      Hi to all ,
                      i really can not understand that AML Boards must be flashed in so many different Ways !!! .
                      Why not one Method for all AML Boards ??? nice Day to all / gefattern
                        I've tried it by following this guide: https://www.youtube.com/watch?v=m8ch...ature=youtu.be.
                        does not work
                          I resolved with new usb cable, it's ok
                            I had same error ([0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error) while trying to flash my GT1 Ultimate. While flashing, box was connected only via USB to PC, no power supply, no nothing. Then I connected power supply to box, and that solved the problem. Obviously, box wasn't getting enough power via USB.
                            BR
                              Very important
                              I am having problem flashing from Android 6 > Android 7 using a PC with message:
                              DeviceID Time Result
                              HUB4-2 2017-09-18 15:12:44 201 [0x00101004]Erase bootloader/Lowper/Indentify/Error result
                              but the Beelink Youtube video says erase bootloader should be checked on - which is what I did? I get the above message after about 2% processing from start. Is this a power issue??? Please help thanks.
