Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
Originally posted by WeK05 View PostInteresting... The DRM Info screenshot doesn't show HDCP level, but you are still getting HD streaming in Netflix.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Guest
Are the M8S Pro L units that are shipping now have reset buttons? (The latest M8S Pro+ boxes have had the reset switch removed.)
Originally posted by Magendanz View PostAre the M8S Pro L units that are shipping now have reset buttons? (The latest M8S Pro+ boxes have had the reset switch removed.)
EDIT: As Magendanz commented, It doesn't look like there is a PCB switch below the pinhole. Tapping the hole with a pin (ehh. its a pinhole, right?) does not do anything.
I am sure there must be some kind of reset button/pad available o n the PCB in case of initial flashing or repair.Last edited by thijsnl; 04 October 2017, 20:33.
Guest
Selling one of these devices without a reset switch is pretty obnoxious. It means that if you ever have a bad flash and can't get to Terminal to type "reboot recovery", you're forced to open up the case and find the pins to short. For custom ROM developer like me, that's an incredible hassle. (But maybe that's the point.)
The whole purpose of having a recovery partition is for situations where you can't boot the system and need to have a known safe alternative boot path. Without the reset button, you can't trigger that when it's most desperately needed.
Originally posted by Magendanz View PostSelling one of these devices without a reset switch is pretty obnoxious. It means that if you ever have a bad flash and can't get to Terminal to type "reboot recovery", you're forced to open up the case and find the pins to short. For custom ROM developer like me, that's an incredible hassle. (But maybe that's the point.)
I've just written to Videostrong challenging their absurd design decision, underlining that no user wants to be limited to their buggy factory firmware and that the Pro Plus box would have bombed without custom rom development. May or may not hear back..they did reply to me on another occasion.
Indeed, the Mi Box has no reset button. You access recovery by removing and replacing the remote batteries and then applying power with Back and OK buttons pressed. The deal with the batteries may be because it's a bluetooth remote.
It really is the most stupid decision I have seen in a long time.
After the M8S Pro+ eMMC fiasco, Videostong needs to get their shit together if they want ongoing 3rd party developer support.
Without that reset button, a whole bunch of potential beginner LibreELEC users are going to run into lots of difficulties as well.
In fact I will be compiling a LibreELEC list of Videostrong devices NOT to buy if this is going to be the new norm.Last edited by wrxtasy; 05 October 2017, 08:33.
There are currently 2358 users online. 1 members and 2357 guests.
