Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
So with Mod done above
http://freaktab.com/forum/tv-player-...661#post684661
New spaced out LID ( raised by using plastic washers)
If you're in a tropical area a Fan or Laptop cooler underneath is the go if heat is a Big problem,
Often with Factory Rom, Junk in the trunk running in the Background is the Killer.
Or Kodi with lots of Addons (can be Evil)
Some quick measurements
More testing needed - Quick results
Lid Standard ~Kodi idle 65°C/150°F ~Kodi HD Video playback 87°C/190°F
30mm Fan + Lid with air holes ~Kodi idle 42°C/108°F ~Kodi HD Video playback 55°C/130°F - Fan noise
30mm Fan + Lifted Lid ~Kodi idle 50°C/122°F ~Kodi HD Video playback 64°C/147°F - Low noise
30mm Fan + Lifted Lid ~Kodi idle 50°C/122°F ~Kodi HD Video playback 64°C/147°F - Low noiseMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by P.X View Post5V Input socket - Easier to solder pads are on underside of the board.
Could use USB pads either as an alternative.
I'll try to do a vid/pics as and when possible...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi, see above edit... Have to find a nice switched supply ???
No switched supply that I can see (anyone know better ? let me know).
So I have changed to a silent fan that runs all the time, This is the 5V Pi Fan running at 3.3V with an isolation switch fitted to stop it, as and when.
Power is taken from the 3.3V UART +/- pads through a sub-minature slide switch mounted on the right flank of the box.
Fan is fully silent - 4x rubber sticky pads (made from 3M Double Sided or Generic foam tape) mount the fan to the lid and provide air-flow gap.
Lid attaches with a 2-3mm air gap around the edge.
Power consumption is miniscule.
Previous results
30mm 5V Fan + Lid with air holes ~Kodi idle 42°C/108°F ~Kodi HD Video playback 55°C/130°F - Fan noise
30mm 5V Fan + Lifted Lid ~Kodi idle 50°C/122°F ~Kodi HD Video playback 64°C/147°F - Low noise
30mm Fan(5V) @3.3V + Lifted Lid ~Kodi - HD Video Playback runs at 68°C/155°F Silent
For now I'm testing it with an external usb powered fan to check if the freeze depends on high temperature. If yes I'll try to install an internal PI fan.
Thanks in advance.Last edited by nitro82; 17 November 2017, 19:26.
Video
Pictures
I tried 2 Slots in the lid - 4 / 6 would help, but none also works if you don't want the work. Takes a while with a Stanley knife ........
You can just see the 2mm air gap at the edge
Click for Bigger
Tap 3.3V from the UART Pads - Route Red +ve wire through a Sub-Miniature Slide Switch
Click for Bigger
Slide Switch
Click for Bigger
Overview
Stick fan to Lid - Small squares of 3M (Generic) double sided foam tape 15mm wide
Double thickness works best.
Neg and +ve from switch - I just tinned the ends and inserted into the red PI plug.
Two pieces of double sided tape hold them in place (leave the red backing on)
Click for Bigger
Moved the Wi-Fi aerial to the side position - could put it back on the lid if you want.
HTH
E&OELast edited by P.X; 18 November 2017, 00:08.
There are currently 2548 users online. 1 members and 2547 guests.
