Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
Originally posted by trebor View Post
Today is Christmas Day, the tree is already decorated, the gift can come...
Hi guys,
I got one of these boxes for Christmas and I think I may have broken it already!
I flashed the latest Magendanz Nexus TV rom which worked well. So then I decided to improve the heatsink because the box felt a bit warm. That also went well after a struggle to get the the heatsink off the cpu chip. Refitted it with some Arctic Silver and it all ran normally, but still felt quite warm. Next I decided to fit a larger HS and this is when the trouble started. Ever since then the HDMI output seems to have stopped working. The AV output does work, so it's not the software. I think I must have disturbed something when I was fitting the HS. I've put the original HS back now in case the larger one was touching something. Still no o/p from HDMI.
Any ideas, please?
Thanks for any help, cheers.
Any ideas, please?
Thanks for any help, cheers.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I hate to say it, but I did the same thing, and no video output. I just purchased a replacement. Did not try the AV port.
I wonder if your AV port was working, mine definitely is. Not sure I want another one, they seem quite fragile.
Anyway, today I'm going to hit it with my hot air gun to see if I have any bad solder joints. Sometimes if I flex the pcb the HDMI o/p comes to life for a split second. No harm in trying.
Cheers
Thanks for the reply clarkss12. I did see your post where you said you broke yours, seems we are in the same boat!
Cheers
Edit: connected my box via an AV cable, but no video output. But, I had already killed the firmware that was running on it by trying to update the firmware with the burning tool.Last edited by clarkss12; 29 December 2017, 16:42.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Can you turn this box on and off using a remote? Am looking to replace my RPi as a libreelec device and looking for a box that will not force me to unplug and replug the power cable everytime I need to use it.
Can this box do it since it has no hardware button? Can the BB2 Pro do it since that box has one?
Originally posted by Doktor-X View PostI know what you meen i also have pi but i have buy ir swich to controle power remotly
Originally posted by Freaking View Post
How do I switch between Libreelec and Android since it has no Hardware power button? Can I do that with the remote that comes with it or something like the Minix A2 Lite?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 2394 users online. 4 members and 2390 guests.
