Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
Originally posted by drmhussein85 View Postcheck out this method.. instead of pressing reset button short the pins
https://youtu.be/ZPtmwwEpB3g
Originally posted by rimasi98 View Post
Done with all 3 alternatively and same result
Does it stop at 2% when you use USB and load IMG and press Start before shorting (keep shorted) while connecting USB ?
If you select
Erase Flash > Force Erase All
it may help but you will lose Level 1 Widevine !!!
Maybe PM Magendanz to see if he has any idea - He is the expert.
All 3 are -ve so no different.
If you select
I tried FORCE ERASE ALL but no successstill the same error.
Yeah i've pm Guest for help, still waiting a response. Hope i can get out of this because would help others to.
Thank you for you help
Guest
Here's what works for me:
- Open case to expose the PCB
- Load "known good" burn package (.img file) into latest Amlogic USB Burning Tool.
- Click Start with app default settings
- Short the PCB pads for the reset switch
- Connect male-to-male Type A USB cable to USB OTG port (and nothing else!)
If at this point the flash begins, you can release the reset switch. Your bootloader was fine and you don't need to reset using Mask ROM mode. Shorting pins should be considered only as a last resort when you know your bootloader is corrupted.
If not...
- Ensure USB cable is still connected (and nothing else!)
- Short the pins shown in this image: http://freaktab.com/node/685682
When you hold them for a second or two, you should hear the WorldCup driver recognize the device in Mask ROM mode and the flash should automatically proceed.
Where are the factory_update_param.aml, factory_update_param.ubt, and u-boot.bin files... I had considered that but i didn't find these files, Mecool M8S PRO L only got .img file
check this thread
they said that you can get those file from amlogic custom tool.
am not familiar with this tool
If not...
Please make a video tutorial with the short pin and program procedure because i can't believe i'm doing this wrong, i'm following everything you said.
And please tell me where are the files to put in the SD card when we unpack with Amlogic costumization tool... They are not at level 1 on C:/Amlogic/Custumization tool/tmp directory because only the UBOOT is there and some files with diferent names than i need.
apart from this reset issue.. I can confirm that xposed works pretty fine with this device.. using material design xposed by dvd and xposed.zip for arm.. not arm64, which is weird because I thought this is arm64 device.
of course I don't recommend to install it unless you you are very familiar with xposed and its modules as it may result in serious system issues.Last edited by drmhussein85; 24 January 2018, 13:31.
There are currently 2381 users online. 2 members and 2379 guests.
