Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
Originally posted by antmanv1 View PostI ask because when searching the posts here, the vast majority of posts are about the Mecool M8S Pro L . Is that because it's a newer model? When comparing the specs, the BB2 Pro seems to have similar if not identical specs more or less. I'm satisfied with my purchase.Both models are pretty cheap actually. I don't see how you can go wrong considering you can pick these up for under $30. I've made more expensive mistakes in my day! I value the opinions of other users so let me know your thoughts, please.
thanks,
ScottMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by looun View Post
can you try Amazon Prime Video ? if work
Amazon Prime Video app is not availible for this device in Google Play Store.
Installed with AptoideTV
First app Amazon Video - Error with information that video cannot be played blah blah blah
Second app Prime Video (remote doesnt work, tested with mouse) - video played for 2 seconds but after - ForceClose.
//edit
Even I've installed Amazon AppStore, succefuly logged in but there wasn't any app availible for me.
try latest ATV amazon-video_4.3.14-googleplay-armv7a.apk or old 4.2.43-nvidia-arm7a .
if not work, try to setting HDMI 1080 output, M8S PRO L have only HDCP-1.4 (1080) not HDCP-2.2(4k). Check with DRM Info.
Originally posted by meciu View Post
Tested.
//edit
https://www.dropbox.com/s/eoh0mkukyb...rmv7a.apk?dl=0
Edit: crosspost !! Same as above
Originally posted by looun View Posttry latest ATV amazon-video_4.3.14-googleplay-armv7a.apk or old 4.2.43-nvidia-arm7a .
First linked app (amazon-video_4.3.14-googleplay-armv7a.apk) doesnt work, error in app
//edit
Second app (this one from nvidia shield) doesnt work too, still the same error in app.
Originally posted by meciu View PostOkay, so..
Today I've recieved my Mecool M8S Pro L with Voice Control.. i was quite suprised that it came with:
-newest FW "M8S PRO L-userdebug 7.1.2 NHG47L 20180417.150752.V0213"
-Microsoft Playready DRM Supported
aand
-working Miracast app - succefuly streamed screen from Nexus 5X and windows laptop.
Sounds like another improvement from Videostrong.
btw - second app is App Extractor
allright, final test and result is the same,
I think yes
You can set kodi to run at autostart but when you press Home button it will return to Android launcher.
You need to install XBMC Launcher, set it to run kodi and then everytime when you press Home - it will launch Kodi.
https://play.google.com/store/apps/d...n.xbmclauncher
There are currently 2337 users online. 0 members and 2337 guests.
