Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
Originally posted by fafan View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Appys View PostI dont think Prime Video works on these boxes
Use this method
Amazon Prime on the Pro L - needs ethernet to avoid buffering !!!
Originally posted by mymo View PostI found a way to watch Amazon prime contents on this device.
It can't be done through the Amazon app as we all know now, if nothing has changed since the last time I tried, but it can be done through Kodi. All you need is
Kodi 18 Leila (I used the latest Nightly)
Amazon addon by Sandmann79 (it can be installed through this repo https://github.com/Sandmann79/xbmc/r...gins-1.0.2.zip)
Once finished installing, open the Amazon video or Amazon Vod addon (depending on the country you live in), and configure it by entering your email, password and the secret code that will be sent to your email account. Then it will automatically install some add-ons upon which it depends and ask you to enable Inputstream. Don't forget to select "playback with Input stream" during the configuration.
There can be still issues with the subtitles, otherwise the add-on works like a charm... I tried HD stream so far, I haven't tried full HD yet.
EDIT: Well, not like a charm, but it works
No, didn't work last time I tried it.
Amazon have release new generic APP "Prime Video" for lot of device, now Ultra HD and audio 5.1 work with some device: MI box , tecnicolor skipper ecc..
Can you try again ?
Originally posted by looun View Postlast firmware have Microsoft Playready DRM Support, so it should be work.
now it's no more "Amazon prime video" exclusive sony tv and shield APP.
Can you try again ?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Can you try again ?
Repeat it wont work, amazon doesn't let it work yet on generic atv devices as these.. Tried a week ago for crashes.. Here's some proof of incompatibility .
lot of device are not official support yet, but installing APK prime video 4.7.9 apk playback work like mi box.
Concerning the file posted on reddit, it is a nice interface for Android TV OS, but still will not work, just a constant loop when trying to play a video then an error.
Hope that helps ya.
Wanderer190, do you have tested the prime video 4.7.9 apk on the new m8s LB version with microsoft playready drm enabled?
Originally posted by natman View PostWanderer190, do you have tested the prime video 4.7.9 apk on the new m8s LB version with microsoft playready drm enabled?
Originally posted by Doktor-X View PostWhare i can find good BLUETOOTH air mouse, i cant find anything
I haven't found one either, but I did find a BlueTooth Voice Remote, but not with a real air mouse.......... for less than $8 USD. Great for Kodi and the Android TV OS, but not very good for the touch screen versions of Android...........
Could you please provide the link for the BlueTooth Voice Remote?
Does the voice function work on the MeCool M8s Pro L?
Thanks heaps.
There are currently 2982 users online. 1 members and 2981 guests.
