Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
    there is some hope that HDCP 1.4 will be upgrade to 2.2 for 4k VOD , or it's hardware limit?
      I was quite happy using the v09xx OEM FW as supplied, but then found some newer videos, h265, wouldn't play (jerky pixellated smeary rubbish). Loaded latest v09xx Magendanz ATV ROM and all good, playing smoothly.
      Just tried a 1080p x265 and it played without issue in Kodi and in VLC.
      LQ revision ? Is that the original boxes ?? Where are you getting your info please ?
      My understanding is new rev is LB and old is LQ. Should be at the end of the barcode on the bottom of the box I think it was (I chucked my box).
        I have the first revision I believe .I got it when it first came out last year.
        Have never updated the firmware.
        What's the latest stock firmware I saw a thread that included one from late last year but then saw someone mention a 2018.
        What are everyone's thoughts on it .I have a old model remote so I hear I need to pair my mobile to get past the screen .
        I also have never updated these boxes before .Is the ota method with the micro SD card safe? Do I have to wipe data?
        Thanks .
          Yes most of mine were, and no doubt still are, fine but I came upon a few that needed the Magendanz version to run smoothly.
          Thx.
            Originally posted by Albertron View Post
            Hi. I have installed a New launcher, but I dont know how to put this launcher predeterminated. Anyone knows how to put any launcher predeterminated and the home button go to this New launcher? My rom is scv2 atv
            Use home switcher app.
              Originally posted by dionz9 View Post
              Could you upload to other site please, i cannot register/download from freaktab.org. Regards.
              +1
                Hi
                Someone have a link for download these firmware M8S_PRO_L-NHG47L-20180316.143701.V0213.img M8S_PRO_L-NHG47L-20180417.150752.V0213.img ??? Snk.
                  [QUOTE=Darkgrey007;n723828]Hi
                  Someone have a link for download these firmware M8S_PRO_L-NHG47L-20180316 freaktab link not working.
                    [QUOTE=supermal;n723832]
                    Originally posted by Darkgrey007 View Post
                    Hi
                      [QUOTE=alloy1124;n723965] Thank you!!!
                        Has anyone been able to get HDMI RAW audio passthrough working with DTS-HD and TrueHD with stock or any custom rom?
                          Originally posted by Magendanz View Post
                          Just for reference, I created a couple of Amlogic burn packages for these two new OEM firmware releases:
                          I have LS version and install M8S_PRO_L-NHG47L-20180417.150752.V0213
                          wi-fi not working ((
                            Downloaded the >> M8S_PRO_L-NHG47L-20180417.150752.V0213.IMG << file posted by Alloy1124 and burned it to microSD card using the BootcardMaker v2.0.0.2 that Magendanz has posted on his mod link. Inserted the microSD card into my "L" box with the model ending in "LQ", and using a terminal emulator inside Android, I typed "reboot update". After a few minutes, the box booted into Android with the Bluetooth Remote pairing screen. Reading that others were able to get past that screen using their Android phone, I gave it a try. My Android phone paired with my "L" box very quickly after I was prompted to type in the code that was displayed on my TV screen. I tried all kinds of different button pushes on my phone, even got past the remote pairing screen, but I could not get the box activated. After several different attempts using my phone, I gave up and used my Bluetooth Voice remote that came with my other "L" box with the Bluetooth Voice remote.
                            One thing I learned when pairing my Bluetooth Voice Remote with different devices, I have to remove the battery for it to reset.
                            Anyway, using my Bluetooth remote from my other box, it paired right away after removing and replacing the battery in the remote. So, I got a clean install with the April 17 firmware. The Bluetooth Voice Remote even works with the Google Assistant, so I can ask her what time it is, or the weather and she answers me (more than I can say for my grandkids). I did check to see this firmware update enabled the "Microsoft Playready DRM", but it did NOT. From what I read, the newer "L" boxes have that supported, but this firmware did not do it on my box, perhaps that is a hard coded function.
                            Edit: I just checked again, and for whatever reason, now "Microsoft Playready DRM" shows that it is SUPPORTED. Of course, I don't know what apps use that Microsoft Playready DRM.
                            Edit 2: As Supermal noted, this firmware kills the WiFi on the LQ boxes, but I don't use WiFi on any of my boxes.
                              You need firmware for LQ boxes or megendanz custom rom.
                                This is getting slightly confusing ??
                                HW 1 = LQ (my boxes) came with V 03/06/09xx FW
                                Then I saw mention of new LB boxes (V02xx) and now LS is being mentioned ???
                                Someone needs to do a compatibility chart ...
                                Please post exactly what works / doesn't
                                From clarkss12
                                LQ (OEM:V03/06/09xx)
                                + V02xx ~ BT=YES, WIFI=?, MS-PR=YES
