I'm using this rom http://freaktab.com/forum/tv-player-...om-android-7-1
Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
Hi all
I'm having come discomfort with the HDMI interface of the box. Namely, whenever I click on menu item, or I select the field for keyboard entry, there is change of the display mode and my LCD TV (Sony 757 LED TV) displays the channel info mode (i.e. HDMI2: connected M8S Pro L, 1080p.....) which covers the screen and I need to wait to disapear. It happens with every click and it's not nice to wait for the info to go away.
Changing the HDMI mode (1080p to 720p, or the refresh rate doesn't help).
TV is working fine with other TV boxes with same resolution/mode, and this happens with different HDMI cables...
Any ideas?
Any ideas?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Sounds like your TV is wanting to setup information about that device that is NOW using HDMI 2. Go into your TV settings and assign this device to that HDMI input, that should solve that issue. I had a similar situation.
I searched and I think that the issue is not the HDMI and video resolution, but the sound. The info bar is displayed only when the TV box sends stereo sounds. I disabled system sounds and the situation is now improved. Everyone with a Sony LED tv would experience the same problem, so a bit of tips and tricks
Originally posted by BPENL View Post
Just the one from play store.
Originally posted by shuot View Post
Is the AndroidTV version of the Netflix app allow offline viewing? (Downloading episodes)MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
No, it does not. The download function is for mobile devices so they can download the media from a WiFi connection and watch when not WiFi is available.
Is it possible to also, in same time, install the mobile version of the Netflix App?
Okay, so..
Today I've recieved my Mecool M8S Pro L with Voice Control.. i was quite suprised that it came with:
-newest FW "M8S PRO L-userdebug 7.1.2 NHG47L 20180417.150752.V0213"
-Microsoft Playready DRM Supported
aand
-working Miracast app - succefuly streamed screen from Nexus 5X and windows laptop.
aand
-working Miracast app - succefuly streamed screen from Nexus 5X and windows laptop.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by antmanv1 View PostWhen I bought my Mecool BB2 Pro, I thought it sounded pretty robust with it's Octacore AM Logic processor and all. Is the M8S Pro L that much better? I just asking 'cause it seems like the one everyone is talking about.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I ask because when searching the posts here, the vast majority of posts are about the Mecool M8S Pro L . Is that because it's a newer model? When comparing the specs, the BB2 Pro seems to have similar if not identical specs more or less. I'm satisfied with my purchase.Both models are pretty cheap actually. I don't see how you can go wrong considering you can pick these up for under $30. I've made more expensive mistakes in my day! I value the opinions of other users so let me know your thoughts, please.
thanks,
Scott
There are currently 2399 users online. 0 members and 2399 guests.
