Thank you!
Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
Ok, I received myMECOOL M8S PRO L and installed LibreELEC on the nand. watched a few shows and ran fine, only question i have is it seemed to run hot and from i have seen online this is a known issue. will this cause any play back issue, think i saw it up to 160 Fahrenheit? what is the highest safest temp this can run at?
Thank you!
Originally posted by LilSnoop40 View PostOk, I received myMECOOL M8S PRO L and installed LibreELEC on the nand. watched a few shows and ran fine, only question i have is it seemed to run hot and from i have seen online this is a known issue. will this cause any play back issue, think i saw it up to 160 Fahrenheit? what is the highest safest temp this can run at?
Thank you!
176°F
From what I read.
Overheating Thread, see - Here and Page1
Simply lifting the lid and placing vertically helps quite a bit see graph page1Last edited by P.X; 17 January 2018, 13:25.
Originally posted by drmhussein85 View Post
I think no reset button..
if you are in bootloop try pin shorting method
I use this to pin shorting my box and it didn't work ( http://prntscr.com/i35jvx) ... USB_Burning_Tool is still give me and error at 7% : "UBOOT/Disk initialize/Send command/Error result'
It only turns on the blue led of the box.
There's no info whatsoever about unbricking the PRO L box and it's fustrating trying to get this booting up!
Originally posted by rimasi98 View Post
I brick my Pro L so what i'm supposed to do??
hi friend
1. put twrp.img file into sdcard
2. rename it to recovery.img
3. put any rom file into sd card
4. place the sd card into the tv box
5. press menu/recent apps button on the remote while plugging the power in the tv box, keep releasing and pressing the button until device boots into twrp
5. if didn't work from the first time repeat step 4 many times until you boot into twrp
6. install the rom using twrp
hi friend
A light at the end of the tunnel... Best info i've got utill now... Can be any twrp img file? Can it be the latest twrp img file from their website?
twrp for amlogic q20x, the others are not working
try to search for it.. you can find it somewhere on freaktab.. if you couldn't find I will try to upload it for you
Originally posted by Freaking View PostHas anyone used the Minix A2 Lite with this box? I am trying to get the IR on/off button on the remote to wake up or shutdown and turn on again but I have no luck. Please dont tell me I just wasted 25euros for a useless remote.
https://www.itead.cc/search/result/?...OAP+Smart+Home
https://www.youtube.com/watch?v=6nQV5XO1SXc&t=20sLast edited by clarkss12; 21 January 2018, 16:16.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
i think for this you have to mod your keylayout.file , with the right values , but i am not a
Pro in that , a "Search" here maybe helps finding correct Infos , good luck / gefattern
There are currently 3524 users online. 1 members and 3523 guests.
