What do you mean GA having suitable input options??? I can control my over head lights from this box using GA. My light switch is a WiFi enabled switch.
Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
What do you mean GA having suitable input options??? I can control my over head lights from this box using GA. My light switch is a WiFi enabled switch.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by apoklyps3 View PostDoes this box really have Gibabit Ethernet?
Only get close 100mbps in speed test.
All my other devices in the same network go way beyond thatMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Doktor-XIs casting works for you guys i have oneplus 2 and have try stock 6.0.1 but also 7.1.2 and 8.0 roms but nothing is working
casting from youtube on a Pc(win7 and 10) works ok.
Im on the factory rom.
Sent from my Redmi Note 3 using Tapatalk
Hi there,
I am getting stuck while trying to get android installed back to my M8S Pro L. I have thousends of firmware versions downloaded. I copied them with sd burning tool to SD, I entered "reboot recovery" (ssh to the internal installed LibreElec), but nothing happened. It stops on the "mecool" screen without doing anything. What can I do?! The player has no recovery button. The two keys described inside this Threat dont work to start any installation.
When I use the SD card burning tool it makes 2 partitions. The first one is empty inside windows storage managment, the second is with datas. Is that right, should it be like that?!
Please help, Thanks
PS: I dont have a USB cabel with both sides the same end, so I cant use USB burning tool. Since there are holydays I cant buy one.
I did now make my own USB A to USB A cabel through connecting 2 old cables, I always connected 2 same colors. When I connect M8S Pro L to the PC the Mecool boots to internal. The burning tool doesnt regognize it. I tried again "reboot recovery" and i tried several keys on the remote. I dont get it recognized by my computer. I got stuck.
edit: drilled to housing, made a shurtcut to the two reset pins, at the moment it is does format...lets hope the bestLast edited by flyingernst; 23 December 2017, 18:58.
Originally posted by flyingernst View PostI did now make my own USB A to USB A cabel through connecting 2 old cables, I always connected 2 same colors. When I connect M8S Pro L to the PC the Mecool boots to internal. The burning tool doesnt regognize it. I tried again "reboot recovery" and i tried several keys on the remote. I dont get it recognized by my computer. I got stuck.
There are currently 1137 users online. 0 members and 1137 guests.
