Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
    Originally posted by Jancales View Post
    I can't find any reports about the M8S Pro over heating, maybe I missed them?
    But why this box runs hot and the Pro not? Same processor - same casing and as far as i can notice from the pictures, same heat sink.
    Goog "M8S Pro overheating"
    There's a few ....
      There's a few ....
      I id a Google and couldn't find any. They all talking about freezing during boot, or when Kodi start up, but no over heating reports.
      If you have some links would be appreciated.
          That are the ones I found also, but most of them are about other boxes, and the 2 videos that mention overheating don't actually say or proof anything in the video or comments.
          I doubt it over heats when booting, as that is what both videos are about.
          All the other results are about boxes that over heat, but not specific M8S Pro. An M8 box is a different box.
            My "L" was running over 200 degrees Fahrenheit, before I killed it, trying to modify the heat sink. Yes, it dos run HOT!!!
              Let us know how the replacement works (I think you were getting an L again)
                Keep up with reading, my question is about the Pro not the Pro L. :~)
                  I have the Pro also, when I first received it, I was amazed how hot it "felt" to the touch. But after awhile it cooled down. I am using it for my Tvheadend, and Emby servers, running on LibreELEC. I could run test if necessary.
                    Yes, it is supposed to arrive today, but not holding my breath......... hahaha. I will test the temp, and then drill holes in the top of the box, if it is still running 200 degrees F.
                      Thanks for the suggestion, but I will run Kodi on Android, so if you could run any stream in Kodi for an hour and check with CPU temp app that would be wonderful.
                      I know it will run cooler on LibreElec, but I use several apps as well, and that isn't possible then.
                        Just cranked up my "Pro", running my BlueRay rip of Avatar on Kodi. Box connected directly to HDMI input on my 4k TV. Temp. showing 170 degrees Fahrenheit at the start of the video. Will update this message in about an hour.
                        Running Magendanz's ATV mod.
                        Edit: been about 15 minutes and temp reading 186 F. Ambient temp is approximately 73F.
                        Edit 2: After half an hour, temp showing 190F.
                        Edit 3: After 45 minutes, hitting 194F >> 90 degrees Celsius.
                        Media being played, if that matters.
                        Complete name : W:\BlueRay_Movies\Action\Avatar (2009)\Avatar (2009).mkv
                        Format : Matroska
                        Format version : Version 2
                        File size : 39.7 GiB
                        Duration : 2 h 41 min
                        Overall bit rate : 35.2 Mb/s
                        Movie name : Avatar
                        Encoded date : UTC 2015-10-12 16:15:13
                        Writing application : MakeMKV v1.9.6 win(x64-release)
                        Writing library : libmakemkv v1.9.6 (1.3.0/1.4.1) win(x64-release)
                        Video
                        Format : AVC
                        Format/Info : Advanced Video Codec
                        Format profile : [email protected]
                        Format settings : CABAC / 2 Ref Frames
                        Format settings, CABAC : Yes
                        Format settings, RefFrames : 2 frames
                        Format settings, GOP : M=3, N=24
                        Codec ID : V_MPEG4/ISO/AVC
                        Width : 1 920 pixels
                        Height : 1 080 pixels
                        Display aspect ratio : 16:9
                        Frame rate mode : Constant
                        Frame rate : 23.976 (24000/1001) FPS
                        Color space : YUV
                        Chroma subsampling : 4:2:0
                        Bit depth : 8 bits
                        Scan type : Progressive
                        Language : English
                        Default : No
                        Forced : No
                        Audio #1
                        Format : DTS
                        Format/Info : Digital Theater Systems
                        Format profile : MA / Core
                        Codec ID : A_DTS
                        Bit rate mode : Variable / Constant
                        Bit rate : Unknown / 1 509 kb/s
                        Channel(s) : 6 channels
                        Channel positions : Front: L C R, Side: L R, LFE
                        Sampling rate : 48.0 kHz
                        Frame rate : 93.750 FPS (512 SPF)
                        Bit depth : 24 bits
                        Compression mode : Lossless / Lossy
                        Delay relative to video : 2 ms
                        Title : Surround 5.1
                        Language : English
                        Default : Yes
                        Forced : No
                        Audio #2
                        Format : DTS
                        Codec ID : A_DTS
                        Bit rate mode : Constant
                        Bit rate : 1 509 kb/s
                        Bit depth : 24 bits
                        Compression mode : Lossy
                        Stream size : 1.70 GiB (4%)
                        Language : English
                        Default : No
                        Forced : No
                          Thanks for the test and results.
                          Unless you place it on top of your amplifier, that is indeed an incredible temperature, and I'm surprised that there aren't more reports about it on this forum.
                          If it runs that hot I'll have to give it a miss, but I wonder which box to get, because everything I received in the past 6 months runs over 80°C.
                          I noticed you were also active in a thread on the LibreElec forum, and see those guys post that their boxes run 40°C, which I can not believe.
                            Do you need octacore ? If not: The pro+ is great. Runs cooler.
                            Bluetooth doesn't work with my Rii so no advantage for me really.
                              I don't really need octa core, but I fancy the extra ram, and only the S912 has that option.
                                Fair enough.
