if you are in bootloop try pin shorting method
Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
Originally posted by Axe View Post
if you are in bootloop try pin shorting methodLast edited by drmhussein85; 09 January 2018, 10:35.
I am sorry for bothering you, but can you explain me in short how to do that ''pin shortcut method'' ?
otherwise you can install the app called reboot from play store and use it to reboot to recovery or bootloader.. that is when you are not in bootloop
Originally posted by Doktor-X View PostYou have twrp in superceleron and Magendanz rom
other thing regarding the reset button.. there is another way to go to update rom.img via remote according to another post here .. you can hold the 3 dots key in the remote while adding power.. this will boot any .img file placed in the sd card
Originally posted by drmhussein85 View Post
I can't find the roms.. can you refer to them please.. or even try to upload twrp for me..
http://freaktab.com/forum/tv-player-...android-tv-7-1
http://freaktab.com/forum/tv-player-...oid-tv-version
thank you sooooo much.. I have successfully flashed nano gapps varient of Magendanz rom.. and now the device is much more cooler.
now I have only one very small issue to make the device even more cooler.. I want to set live wallpaper for my device but I failed.. I tried many of live wallpaper apps on play store and unfortunately all of them didn't work for me.. anyone has a fix??
I found a fix for live wallpaper problem.. here it is if anyone is interested:
1. download live wallpaper picker apk from here
2. make it a system application with link2sd or similar app
3. reboot and go to your wallpaper settings choose live wallpaper and then choose your favorite live wallpaper.. N.B. if you don't have any.. go to play store and download any live wallpaper app.. one suggestion is (Earth & Moon in HD Gyro 3D Parallax Live Wallpaper).. bretty cool oneLast edited by drmhussein85; 24 January 2018, 13:49.
hello, noob question about this box. i just ordered 2 of these:
MECOOL M8S PRO L YouTube 4K Netflix HD Streaming 3GB/32GB Android 7.1 Amlogic S912 KODI 17.3 TV BOX 802.11AC WIFI Bluetooth LAN HDMI
https://www.geekbuying.com/item/MECO...ck-386124.html
they are arriving on Monday, i just now saw this post and see there isn't a reset switch on this box. if my main purpose of this box is to remove Android and boot to LibreELEC am i SOL.. guess i should i found this post earlier?
after further readings now about this box i am wondering if i have made a bad choice "If you consider buying a device for LE, do not buy Amlogic S912!" i want to use this box strictly for Kodi. what is the best option to do this on this box without any playback issues. do i install SPMC, Kodi or can i install LibreELEC even though i found this statement "If you consider buying a device for LE, do not buy Amlogic S912!" and people saying this box runs hot.
please help with feed back it would be greatly appreciated
ThanksLast edited by LilSnoop40; 13 January 2018, 20:39.
There are currently 2394 users online. 2 members and 2392 guests.
