Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
    Originally posted by rimasi98 View Post
    But Guest i already tried to use USB Burning Tool and shunt the reset pins but nothing happens and there's no diference because the USB Burning Tool recognises the box. I've tried to flash this firmware "M8S_PRO_L-V0928_TVStock-20180109", also this one: "M8S_PRO_L-NHG47L-20171216.102705.V0928" and also this one: "M8S_PRO_L-V0928_TVStock-20171202" and the result is allways the same when i hit enter:
    ERROR At 2% when i'm not using power cable
    http://prntscr.com/i3pblz
    ERROR at 7% when i'm using both power cable and USB male to male:
    http://prntscr.com/i3pbxj
    PS: I've tried with the latest USB Burning Tool and this 2.0.5.15 version
    Do you got the correct .img files to restore my bootloader because i perhaps might screwed it (i don't know whatelse to do)
    just follow the method I talked about earlier.. press the recent apps button many times while pluging the power.. am sure it will work.. just don't forget to rename the recovery file to recovery.img and put it on the SD card.
    it worked for me many times.
      Ok Guest i tried shorting the 6-7 pin, 7-8 pin, the 17-18 pin counting left side (as you said it works on your Mecool M8S Pro) and i did it with power cable + USB male to male... Also recognises by the USB burning tool but gives me the same error:
      Click image for larger version  Name:	123.png Views:	1 Size:	237.7 KB ID:	703993
        I've tried it many times, also with the menu button to.
        The result was allways the blue LED light and a black screen... I've putted the twrp i've shown you and also many others... I think my bootloader is messed up, i don't know if yours were to.
          just give it last shot using this version of TWRP
            http://freaktab.org/a2346c32352b64d3
            I got it recorded, see if i'm doing something wrong:
            The recovery image is that file you gave me:
              http://prntscr.com/i3yb8y
              Wrong.
              You have to press and Hold the button while you put the power plug into the box (or switch the mains on)
              This never worked for me and more reliable is short switch pins while inserting power plug and keep shorted for at least 7 seconds.
              (Left front switch pin to right pin)
                Wrong.
                I've tried now to press and hold while i powered it on but the result was the same.
                Ok i'll give it one last try to the main reset pins:
                  P.X here you have at i've done and the result:
                  I also tried to short pins on the eMMC and the result is allways the same:
                  Click image for larger version  Name:	123.png Views:	2 Size:	237.7 KB ID:	703995
                    https://www.youtube.com/watch?v=f3rWZd7AgG4
                    That looks like the right method now.
                    Can't read the screen, but doesn't look correct for recovery
                      The message is just a warning that is no device connected to the LCD
                        I also tried to short pins on the PCB and the result is allways the same:
                        If you are trying to do the PCB short method on the eMMC then you need to attach to computer and use USB Burn Tool I believe !?!
                        Best to try the USB Burn Tool and the Reset Switch Short method first.
                        Load USB Burn Tool.
                        Switch to English (Menu Bar button 2 - Item "English")
                        Load an IMG File
                        Click START
                        Connect USB A-A male cable (No power supply to box) while shorting RESET SW
                        Tool should detect Box and start a ROM Burn ......
                          RESET - if No Switch Fitted Pro L (and Pro +)
                          Click - Full Size
                          Short RED - Any Black (whichever is easiest!)
                          Click image for larger version  Name:	Reset-Short.RedBlack-ProL1.3.jpg Views:	1 Size:	125.3 KB ID:	704018
                            Load USB Burn Tool.
                            Load an IMG File
                            Yes i've already tried that and it doesn't pass the 2% and give an error:
                            I use the shorting on reset pins and then powered with USB male to male to the pc after i click "Start" on the UBS Burning tool with the loaded firmware
                            PS: if i plug also the power supply it stays at 7% when is formatting and gives me this error:
                              Should say
                              Click START before Connect USB - A-A in above method (EDited)
                              Keep Reset Shorted until Upload Starts automatically ....
                                Click - Full Size
                                All 4??
