Also, is it really a good idea to switch off an android device that way? Doesn't it cause problems if you don't properly shut down the device through the software menu?
Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS
Hi ,
i think for this you have to mod your keylayout.file , with the right values , but i am not a
Pro in that , a "Search" here maybe helps finding correct Infos , good luck / gefattern
This was my best bet http://www.minixforum.com/threads/pr...-remote.16064/
Taken from the Minix forums someone posted a .kl file as you say and a remote.conf. I put those on my box but nothing worked again. I mean it works on H96 Pro +, why shouldn't it work on the Pro L or any other Android TV Box for that matter?
Originally posted by Doktor-X View PostSonoff is smart power switch, this meen that you can connect box power thrue sonoff switch rather then directly to wall outlet and controll power on off using ewelink app
Originally posted by Freaking View Post
Where are the plugs to connect the box to sonoff and the sonoff to the wall outlet though?
I ve searched the net for hours the last 2 days but haven't found a solution.
best to use the search from here , did you used the right permissions to save the kl.files ???
greetings / gefattern
Hi ,
Yes, I changed the permissions through ES File Explorer and both files were copied the their respective locations succesfully.
I ve found nothing about making the Minix A2 Lite's IR Button working in freaktab to be honest.
is it not possible to change your Stock kl.files to your needs ???
Maybe it is more needed to do this , then only changing the kl.files ???
Hi ,
Originally posted by drmhussein85 View Post
the one that worked for me is
twrp for amlogic q20x, the others are not working
try to search for it.. you can find it somewhere on freaktab.. if you couldn't find I will try to upload it for you
it wont recognise any of menu/recent apps buttons and still got no response...
I'm desperating guys... i can't believe there's any video tut demonstrating this :'(
The shunt on my Mecool M8s PRO L doesn't work omg :'(
Neither pressing any buttons of the remote.
I tried the Amlogic_SDcardMaker_BootcardMaker_burnBootCard_v1. 0.1 ticking the "To Partition and Format" option and copied the latest firmware "M8S_PRO_L-NHG47L-20171216.102705.V0928" and "twrp.q201-3.1.1-0"
Came with no result and keeps the Blue LED ON and a black image on lcd
But Guest i already tried to use USB Burning Tool and shunt the reset pins but nothing happens and there's no diference because the USB Burning Tool recognises the box. I've tried to flash this firmware "M8S_PRO_L-V0928_TVStock-20180109", also this one: "M8S_PRO_L-NHG47L-20171216.102705.V0928" and also this one: "M8S_PRO_L-V0928_TVStock-20171202" and the result is allways the same when i hit enter:
ERROR At 2% when i'm not using power cable
http://prntscr.com/i3pblz
ERROR at 7% when i'm using both power cable and USB male to male:
http://prntscr.com/i3pbxj
PS: I've tried with the latest USB Burning Tool and this 2.0.5.15 version
Do you got the correct .img files to restore my bootloader because i perhaps might screwed it (i don't know whatelse to do)
Guest by saying using Mask ROM mode by shorting pins on the eMMC you meant shorting the reset button pins right this one:
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Nope, I mean shorting pins on the eMMC. Details here: http://freaktab.com/forum/main-categ...short-location
This is what you do after you've corrupted your bootloader. It's really meant as a last resort, but it's saved my bacon many times.
Originally posted by rimasi98 View PostGuest by saying using Mask ROM mode by shorting pins on the eMMC you meant shorting the reset button pins right this one:
Edit: Recovery mode, NOT masked ROM mode.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I took the .kl file of a2 lite from the minix forums and copied it to my box but nothing changed. I think something else must be changed because the IR button doesnt work through RF like the other buttons on the a2 lite. Maybe something inside the boot.img?
i am not sure , hope you can find a Solution .
There are currently 3433 users online. 0 members and 3433 guests.
